Old Feb 20th, 03, 02:28 PM
kacy kacy is offline
Post
i have a 4spd that i was told is for my 69 it has a cast case and 9 bolts that hold the cover on
97 anniversary z28 for sale
Old Feb 20th, 03, 07:30 PM
Jonesy Jonesy is offline
Mike
Post
Any numbers cast into the side of it. Post all numbers and we'll see what you got.
Old Feb 21st, 03, 02:56 AM
oger oger is offline
Post
Are all the shift levers in the side cover? If so it's a Saginaw.
Old Feb 21st, 03, 10:15 AM
Post
It just dawned on me if it has 9bolts it some sort of a Borg. Warner trans. It didn't come out of a Camaro originally.
Old Feb 22nd, 03, 09:19 AM
Post
the levers dont go through a cover the only cover is located on the top of the tranny...i counted the teeth on the gears inside for the front and it had the same numbers as a muncie but i dont know here are the #s i found
2603435 g2578 under the shift levers and
2603734 on the tail shaft housing
Old Feb 22nd, 03, 10:46 AM
novaderrik novaderrik is offline
Post
ford toploader?
you don't plan sincerity.
you have to make it up on the spot.
my 1974 Monte Carlo & 84 Turbo Buick
86 Monte SS that should probably be crushed
Old Feb 22nd, 03, 01:34 PM
Post
It sure is a top loader. At one time it was a farely common swap before the ST10 came out but you don't see many in Chevs anymore.
