Pinion Angle Adjustment - Team Camaro Tech
Old Mar 16th, 03, 03:41 PM
Cameron Cameron is offline
Post
Before this weekend, I had been experiencing a vibration in the shift handle that started at aroun 75-80 mph. Having the drive shaft balanced helped, but did not cure the problem. This weekend, I started playing with drive line angles. The tranny is pointed down at 4 degrees while the pinion was down at 1 degree. I added some 2 degree shims between the leaf springs and and the rear end and brought the pinion up 2 degrees. I also eliminated the Poly spring pads to prevent flex. Now, the pinion is point up at 1 degree and the tranny is pointing down at 4 degrees. The vibration has gone away and now waits until the car gets to around 90mph or so. The intensity of the vibration has gone down some too.
Anyway, on to the question. Obviously, I need to further adjust my pinion angle, the question is how do I do it? Another 2 degree shim would bring the pinion angle and the tranny angle to within 1 degree of being parallel. The problem is, that if I stack two, 2 degree shims between the leaf spring and the spring pocket, the locator pin that sticks out of the spring (I have Hotchkis leaf springs, if that matters) isn't tall enough to go through both shims and stick out of them enough to engage the hole that is in the spring pocket. What are my options here? Are there 4 degree shims available that have a hole for the locator pin on the spring and that also have a locator pin on the other side to locate the spring pockets? Is there another solution?
49 Chevy 3100 Project
Acro Sport II Biplane
69 Camaro
400 Small Block
AutoGear M22 4 Speed
Old Mar 17th, 03, 01:49 AM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Post
Cameron,
Did you think about shimming the trans mount also to bring it up a couple degrees? I suppose if there's not enough room in the tunnel, that wouldn't be an option, and might affect the shifter position.
Has anyone shimmed the trans mount or even the crossmember a degree or two without problems?
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Mar 17th, 03, 11:28 AM
Post
Yes, I have considered that and I have tried it. Since the drive train is hinging on the motor mounts and I am adding shims a few feet away from the hinge point, there is very little room to make changes to the angle itself. I added a 3/16" shim under the trans mount and I couldn't detect any change in output shaft angle.
69 Camaro
400 Small Block
Old Mar 18th, 03, 08:58 AM
rickmack rickmack is offline
Post
Where did you get the shims? I need to do the same thing to my car.
Old Mar 18th, 03, 10:25 AM
bretcopsey bretcopsey is offline
Post
Would using a longer center bolt be an option? You would probably have to put some washers/spacers under the "head" of the bolt to keep it up high enough.
Check out this link:
http://landrumspring.com/racing/accandparts.html#center
Bret Copsey
'68 Camaro base coupe http://memimage.cardomain.net/member...04_24_full.jpg
'51 Chevy 3/4ton http://memimage.cardomain.net/member...25_55_full.jpg
Old Mar 18th, 03, 01:40 PM
GMJim GMJim is offline
Jim
Post
Cameron
What ever the angle of the trans to shaft is eg. 3* negative, the pinion to shaft angle should cancel it eg. 3* positive. Besides, if you try to get a zero zero angle, it will change as soon as you fill or empty the gas tank. Usually driveshaft vibration is felt at lower speeds. What is the condition of the tail housing bushing? A vibration like this can be caused by a worn bushing or yolk or both. Assuming the U joints are installed properly and the flanges aren't bent from installing the joints with a hammer. I had a customer with the same problem. After he had another garage do everything, driveshaft balance etc. etc. we installed a $3.00 bushing and the vibration was gone.
Jim
Jim Goodlad
jim@hurst-drivelines.com
760-859-6635
Old Mar 18th, 03, 06:08 PM
Post
Rickmack,
I got the shims from Summit. Just do a search on Competion Engineering. The angled shims are one of their products.
Jim,
Tailhousing and bushing are new. U-Joints have less than 5,000 miles on them. I just had the driveshaft checked and balanced. Slip yoke is the one that came with the car. Pinion bearings also have less than 5,000 miles on them. I didnt' see any major wear on it. Everything should be tight and vibration free, but it isn't. Driveline angles are almost last on the list of things to try.
Also, adding the 2 degree shim between the rear end and the springs and the 3/16" shim under the tranny mount definitely caused a reduction in vibration. I think that I should at least investigate the drive line angles as a cause for my vibration some more before I rule them out.
Another source for the vibration might be drive shaft flex at high RPM. My only recourse for this would be to have a new drive shaft built that had a larger diameter than my current stock shaft. Right now, I would rather spend money on shims than I would a new drive shaft, even though it may come to that.
If anyone has any other ideas as to the source of my vibration, I would love to hear them. I am going to do some more testing so I can document exactly when the vibration starts, if it is more pronounced when I am heavy on the gas or gradually speeding up, etc.
69 Camaro
400 Small Block
Old Mar 19th, 03, 06:13 PM
2SLO4ME 2SLO4ME is offline
Post
Cameron take the drive shaft out of the car with car on level ground with equal size blocks under each wheel to where you can get under the car and measure with a angle finder the degrees at which the output shaft of the trans.is pointing and record it down on a piece of paper.Then go to the rear pinion yoke and turn it to a vertical position and measure the angle at which it is pointing and record it down.The 2 measurements should total 180 degrees.Depending on what kind of set-up you have on the rear-end you may want the pinion to point down a couple of degrees and sometimes a little more.Also draw a imaginary line coming out of your trans.output shaft,and then draw another line coming out from your pinion yoke.These two lines should be on the same plane and not cross one another.I hope this will help you out. [img]graemlins/thumbsup.gif[/img]
Old Mar 20th, 03, 04:29 PM
Post
2Slo,
Right now, my pinion needs to rotate up 3 degrees in order for the imaginary lines from the output shaft and from the pinion to be parallel.
I am going to try some more shims, but I will be in Bristol, TN from tonight until Sunday night so I won't be able to get to it. I'll let everyone know what happens. Hopefully, that will fix the problem. I will just have to get some spacers to go under the pin (bolt) so that it will be long enough to go through both shims and still stick out enough to engage the alignment holes in the spring pockets.
69 Camaro
400 Small Block
Old Mar 21st, 03, 01:54 AM
HwyStarJoe's Avatar
Post
Cameron,
Did you change the rearend by chance, and have to move or change the spring brackets? I thought about that when you first posted. I'm just wondering because the spring brackets on the axle tubes have to be welded on at the proper 4 degree angle.
Just throwing out ideas....
SEMA ACTION NETWORK
Old Mar 23rd, 03, 06:38 PM
Post
Joe,
Yes, I did have to change the rear end last summer. I used an 8.5" 10 bolt out of a 72 Nova. I didn't change or modify the spring pockets though. Hopefully, I can get some time in the next couple of days to do some testing, but I think that the problem lies in the pinion angle.
69 Camaro
400 Small Block
Old Mar 25th, 03, 10:10 AM
Post
I think that I may be going about curing this vibration all wrong, so I started a new topic that is more related to vibration solutions rather than pinion angle adjustment. Go here http://www.camaros.net/cgi-bin/forum...&f=18&t=000148 to see it.
69 Camaro
400 Small Block
Old Apr 1st, 13, 09:18 AM
bolandps bolandps is offline
Paul
Default Re: Pinion Angle Adjustment
Hi guys, I know this is an old post, but it was helpful. Curious what the final solution was? I am having the same problem, and after shimming the trans without much movement, I am now considering lowering the engine, wondering has anyone done this before?
