Old Feb 17th, 03, 03:59 PM
AJBorski AJBorski is offline
Post
I just installed my (brass) pilot bushing into my 502 and noticed that I chipped it around the outside. Is this a problem? Should I start over even if the inside surface is not damaged? Please help me out.
Thanks-Tony
1969 Camaro 502BBC T-56 trans
Old Feb 17th, 03, 04:16 PM
Ed Ernst Ed Ernst is offline
Smile
I would think that as long as the press fit is tight and the chip area is not a contact point it should be OK. But myself, being a nitnoid (my wife has another name for me ), I'd pull it and replace it. Not a lot of $'s involved here for peace of mind.
1967 SS/RS L48 convert - 1969 X11 9561 RS
Old Feb 17th, 03, 04:23 PM
ZZ430DropTop67RS's Avatar
ZZ430DropTop67RS ZZ430DropTop67RS is offline
Don
Thumbs up
How about using the roller style?
Use synthetic grease.
Don ~ TC Member #15 Gold
Old Feb 17th, 03, 07:33 PM
Vic_68 Vic_68 is offline
Tech Team
Post
Bushings are cheap and its a pain to pull the trans to change it why take the chance?
Don
I will never use a roller again and would recommend against them to anyone considering one. Both I have used on two different cars were installed carfully with a tool to press them in and both have failed in less than 5000 miles. Also the steel remains are tricky to remove. I would admit maybe I've had bad luck but the bronze bushings never have caused any problem.
Good Luck,
Vic
Old Feb 18th, 03, 09:01 AM
Angry
Thanks for the info everyone... Looks like I am off to get a new bushing, better safe then sorry.
Tony
