Old Feb 19th, 03, 06:57 PM
69ssCamaro4a17yrold 69ssCamaro4a17yrold is offline
Post
I have a saginaw or however you spell it in my 69 camaro. I have a 454 out of a 73 chevy truck that im going to put in. My question is though, How much horse and tourque can this tranny handle?
Old Feb 19th, 03, 10:14 PM
novaderrik novaderrik is offline
Post
my guess is that you will find out how much it can take the first time you side step the clutch at 3000 rpm and get traction..
you don't plan sincerity.
you have to make it up on the spot.
my 1974 Monte Carlo & 84 Turbo Buick
86 Monte SS that should probably be crushed
Old Feb 20th, 03, 01:45 AM
fujimook fujimook is offline
Tech Team
Post
Like Novaderrik said, depends on how you drive it and how it hooks up. Hard launches with any traction and you will be looking for a new tranny real soon. Sags are not very strong but if you don't sidestep the clutch and don't miss too many shifts, they can be fun. Lot of choices with gear ratios in the box. Have a sag behind a mildly built 327 and have had no problems... so far. I don't get real crazy but don't baby it either. Hope this helps.
john
70 Nova, balanced 327+ .030, TRW small dome, AFR 195's, Comp Cams xs268s, Performer RPM, Holley Spdbore dp, self-made cowl cold air and HEI, headers,4 speed, Powertrax limited slip
http://rides.webshots.com/album/29514738sryMYECvOx
Old Feb 20th, 03, 05:06 AM
69X11SS 69X11SS is offline
Post
I had a saginaw in my 75 Camaro with a radically built 400 4 bolt main SBC. It only lasted five trips down the quarter. The chassis dyno shows 620 rwhp. The car has big rear meat with 4.10 gears. Something has to give and it is usually the weakest link. I replaced it with a Muncie M21 and have not had any problems. The 454 truck motor that you are planning to use will probably be just fine with the saginaw as long as you don't beat on it or try to build too much horsepower into it.
There is a fine line between hobby and obsession!
69 SS, 350, 4 Speed
69 350/350 4 Speed Corvette Convertible
Our Cars Click on my Cardomain user name to view both cars.
Old Feb 20th, 03, 09:57 AM
oger oger is offline
Post
If you just drive it you should be ok if you decide to side step the clutch you won't be ok.
Old Feb 20th, 03, 08:21 PM
Angry
Thanks fo the tips everyone...yea i plan on building it up but I was gonna change it over to the t56 6 speed later on..just amking sure that it will work for now...the first thing i need is posi..haha...or else i be getting no traction..
