Old Feb 18th, 03, 06:15 AM
stevo camaro stevo camaro is offline
Gold Member
Post
When adjusting the cable, should there be a clicking sound? I disconnect the cable at the carb, move the cable back & forth, and I don't hear anything. I've been told I should hear a clicking noise. Is the adjuster inside the trans shot? Or the cable stretched? It won't shift up into 3rd & 4th.
67 RS 327, 4-speed, posi, done.
67 Modified, 454, TH-400, posi, under construction.
67 Salvaged RS pro street project, ready for floors & motor.
67 SS 396, 4-speed, basket case.
72 RS, sitting, partially done.
77 Trans Am, complete, sitting.
55 210 post, 2 door.
Some mornings, it's just not worth chewing thru the leather straps"
Old Feb 18th, 03, 06:41 AM
PDQUICK PDQUICK is offline
Paul
Post
The adjuster is in the cable, not the trans. You have to push in hard on the d-shaped metal part of the housing where it connects to the throttle bracket and the pull the cable's sheath out of the adjuster to reset the cable adjuster. Now when you push the cable sheath towards the adjuster housing you should hear the clicking.
Paul D.
Paul D.
68RS/Z28 Klone, Long rod 357 , T-56, 3.89 9"
"You can destroy a man but not defeat him." E. Hemmingway
Old Feb 18th, 03, 05:02 PM
Gold Member
Post
LOL [img]smile.gif[/img] No wonder I wasn't getting anything. I'll give that a try. Thanks.
