Old Feb 28th, 03, 06:11 PM
Mkelcy Mkelcy is offline
Mike
Post
I am about to install the engine and T56 in my 68 Camaro, and wanted to avoid doing the wiring for the transmission while lying under the car. Does anyone have a source for the connectors used on the T56 (mine is from an LS1 Camaro) for the speedometer signal, backup lights and reverse lockout or a suggestion for wiring them?
Also, does anyone have a T56 wiring diagram?
Thanks for your help.
Old Mar 18th, 03, 10:04 AM
rickmack rickmack is offline
Post
The Chevy dealer will have them. There was a post on here last year that listed most or all of the part numbers. (I think it was this board)
1968 RS convertible, 427, T-56, 3.73 12 bolt posi.
Old Mar 21st, 03, 10:11 PM
z28andrs z28andrs is offline
Tech Team
Post
As far as I understand it, the transmission itself has no electrical functions but the skip shift and the reverse lockout solenoids. It has a backup light switch and ths speed sensor, which is a permanent magnet tach.
All of them are individual components.
Old Mar 22nd, 03, 09:11 PM
ramcda ramcda is offline
Post
What do you want in the way of a wiring diagram? Do you just want something indentifying all of the solenoids/connections on the trans?
<a href="http://hobbystage.net/camaro/ramcda/" target="_blank">http://hobbystage.net/camaro/ramcda/</a>
Old Mar 23rd, 03, 03:54 AM
Mike
Post
I received a wiring diagram from O1mrquick (Thanks).
I just haven't found a source for the connectors yet. I wanted to wire the reverse lockout to a shifter mounted switch (think Hurst line lock T handle), the speedomter to my Autometer electric speedometer and the backup lights to, well, my backup lights.
Nothing fancy, just a better integration of the trans into the car than it would be without all those connections.
Mike - 68 Camaro with some stuff done to it; building another '68 with even more stuff done to it.
http://www.camaros.net/forums/attach...2&d=1176782254
Old Mar 23rd, 03, 05:22 PM
Post
If you find a source for the connectors please let us know. I was planning on trying to find one in a junk yard, and cutting off the connectors I need. Unfortunately they rarely make it to the junk yards. The useful parts (like wiring) are usually stripped and resold.
Old Mar 23rd, 03, 06:01 PM
Post
It was on www.thirdgen.org.
12101899 = Speedo (VSS) Connector
12085485 = back up lamp connector
12101857 = Reverse Lockout solenoid
these are all connectors with a bout 12" of wires.
