Heating & Cooling Heating, cooling and air conditioning
Old Feb 16th, 03, 06:37 PM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Post
Guess I can be the first one in this new section... great idea AL
This helps locate these issues sooner without paging thru questions in engine
section..
AttaBoy [img]smile.gif[/img]
Click..is Jim..69RS-LM1 350/255 - 700r 4speed auto.
Our Camaro Webpage
Photos for viewing
Learn How To Post Pics here
Old Feb 16th, 03, 06:43 PM
novaderrik novaderrik is offline
Post
this place is starting to look more like the Chevelle clubhouse everyday... that's a good thing.
Old Feb 17th, 03, 12:27 PM
CamaroJSU CamaroJSU is offline
Post
Ill be a the third. What do yall think about electric water pumps with electric fans on a street car. mostly street and will see some track time. thanks
Old Feb 17th, 03, 12:40 PM
click's Avatar
Moderator .. Jim
Jim
Post
I have not the slightest idea, Im just a pulley and fan belt man myself. Try posting a new question with that in the headline. Good luck [img]graemlins/waving.gif[/img]
Our Camaro Webpage
Photos for viewing
Old Feb 17th, 03, 04:29 PM
Spames Spames is offline
Post
Just based on what I've read here, the elec. water pumps are better suited for strip only.
But, like anything else, there's always a successs story to be found.
Old Feb 17th, 03, 10:03 PM
Snatchin'gears Snatchin'gears is offline
Post
Yah I wonder what size radiator and water flow is typical for the electric pumper. It might be a case of lighter smaller radiators for the drags. I'd figure since I've got the direct drive fan and water pump I'd free up some hp.
Kinda pricey those pumps. My last look at them got the no way reaction.
Old Feb 18th, 03, 05:51 AM
sneakey pete sneakey pete is offline
Post
I'm running a pulley and fan/pump (Stewart stage ii) as well, but I did look into the Stewart elc pump and I am quite impressed with it comparred to a lot of others out there. The good mechanical pumps put out the same or even more flow at top rpm but the nice thing about the electrics is the good flow at low rpm and idle. Stewart has a pretty good question and answer area online and they respond to questions quite fast as well. If I can find the (claimed) flow comparisons I will post them. Barry
68 Camaro, 355, Forged pistons, rods and crank, Edelbrock Alum Heads, Air Gap w/Street Avenger, CC 280H, MSD Dist & Digital Box, T400 w/brake & 4200 stall, 513 gears, 11.66 @ 120 (with 150 shot) Street driven (occasional strip use)
Old Feb 18th, 03, 06:11 AM
Talking
I just found my reply from Stewart and they claim:
Their elec pump puts out 55 gpm which is equal to their mech pump at 2500 rpm
They said all things being the same and with stock pulleys the mech pump will put out
150 gpm @ 7000;
25 gpm @ 1500;
17 gpm @ 1000;
When I quizzed them about power to run the pumps they said your stock pump will use
7.2 hp pumping 100 gpm @ 6000 where as their mech. pump will use 2.9 hp.
I never did find out what their ele pump will use pumping 55 gpm but I guess that depends
on your charging/electrical system.
I think my neighbours kids car uses about 12 hp to run his STEREO system lol.
Hope this helps - Barry
Old Feb 18th, 03, 06:12 AM
Talking
Old Feb 21st, 03, 06:43 PM
Post
You know what. I wonder about the life span of the pump for people who have to run a thermostat.
Old Feb 21st, 03, 10:10 PM
Post
if you run an electric water pump, i don't see why you'd need a thermostat.. you could use an elecctric fan temp switch to turn on the water pump when it needs to be on.
you don't plan sincerity.
you have to make it up on the spot.
my 1974 Monte Carlo & 84 Turbo Buick
86 Monte SS that should probably be crushed
