Heating & Cooling Heating, cooling and air conditioning
Old Feb 23rd, 03, 02:45 AM
JGorms JGorms is offline
Question
I've got unwanted hot in my '84 even with temp lever in cool. This is undesirable in central FL with no a/c. I can see the heater core closed off by the dash lever but warm (well above ambient but not quite hot)air still flows.
Does anyone know the fresh air source for fan?
I shoe-horned in headers that are pretty close to the fire-wall on pass side and suspect it might be the heat source.
I hate unnecessary dashboard surgery so I'd like to hear from the troops in the field before beginning dismantling.
Old Feb 24th, 03, 04:26 AM
Everett#2390's Avatar
Drive a '68!
Cool
Air is received from the cowl panel. Should a gasket on the firewall to seal cowl panel from the engine compartment.
May have to install a water cut-off valve in the heater hose from the engine. [img]graemlins/thumbsup.gif[/img]
Welcome to the Club [img]graemlins/waving.gif[/img]
Give a man a rescue dog for the health of his soul.
My 68 Camaro http://www.flickr.com/photos/everettwn68
Old Feb 24th, 03, 05:24 AM
Spames Spames is offline
Post
It's the nature of the beast. Try to seal off the hood in the back the best you can. I always had warm air coming out of mine, unless it was below 60 deg.
Old Feb 24th, 03, 12:26 PM
69X11SS 69X11SS is offline
Post
If it doesn't turn out to be the heater, you can put some insulation on the inside under the carpet running up on to the firewall to reduce the header heat. Good Luck
There is a fine line between hobby and obsession!
69 SS, 350, 4 Speed
69 350/350 4 Speed Corvette Convertible
Our Cars Click on my Cardomain user name to view both cars.
Old Feb 24th, 03, 06:25 PM
Bantam Bantam is offline
Post
i had a similar prob, underneath the center console in front of the gear shifter is a rubber grommet/plug where the transmission cable comes into the car, mine had to be replaced and the grommet wasnt properly seated thus allowing engine/transmission heat to enter the car. just a thought, you might wanna check it out..
Old Feb 25th, 03, 02:38 PM
Silver69Camaro Silver69Camaro is offline
Matt Jones
Post
Ah yes, my '84 Buick Skylark did this...The Summers were aweful, hot air kept pouring out.
I ended up re-sealing the flapper doors in the heater box. This cured the problem.
Another solution is to hook up another switch for the fan. See, the blower motor runs constantly (maybe they didn't in Camaros, but I'm sure they did in most GM cars), so if the flapper door leaks hot air, hot air will blow out.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
