Heating & Cooling Heating, cooling and air conditioning
Old Mar 16th, 03, 05:18 PM
MStennes's Avatar
MStennes MStennes is offline
Mike
Post
I'm going to a 700R4 and have heard that I need to change my radiator to one with a tranny cooler in it. Do I need to do this or can I run a auxillary cooler instead? I have been told that with a auxilary cooler the tranny will run to cold. The 700R4 needs a radiator with a tranny cooler.
69 RS/SS vert tourer, LS7, T56, Baer, Hydrooost, GW, etc, etc,
Needs more cowbell!!!
Old Mar 17th, 03, 09:51 AM
tloleson tloleson is offline
Tech Team
Post
Mike, you can run just an aux cooler, tap in a trans temp gauge somewhere to find out what temps you're running. You can always adjust that reading. gl
Old Mar 17th, 03, 02:25 PM
MStennes's Avatar
Mike
Post
What temp range should it run at? [img]graemlins/clonk.gif[/img]
Old Apr 4th, 03, 07:49 AM
Rob.Canada Rob.Canada is offline
Post
Tried running an auxillary cooler only, got stuck in traffic jam for 15 minutes, traffic started to move, no mor upshift, tranni cooked.
Trans rebuild $700.00 up
Rebuilt rad with proper cooler $300.00
Finding out the hard way Priceless
I would use the rad cooler along with auxlary cooler.
Old Apr 4th, 03, 09:23 AM
Spames Spames is offline
Post
Hmmmm. .. I ran my 10+ yr old 700 with a B&M trans cooler only for 4-5 years, and didn't have any problems. Maybe I was just lucky?
Old Apr 4th, 03, 02:59 PM
ZZ430DropTop67RS's Avatar
ZZ430DropTop67RS ZZ430DropTop67RS is offline
Don
Post
I agree that you can run just the auxillary, I do it all the time. I make sure the cooler gets good airflow and cooling fan coverage.
I like to see the trans temp between 170-190 degrees.
Don ~ TC Member #15 Gold
Old Apr 10th, 03, 12:08 AM
rcflier55 rcflier55 is offline
Tech Team
Post
Maybe get a transcooler with a electric fan already on it. They will work off of temperature control. On the other hand, by the time you get one of those units you could purchase a radiator at a local parts store for about the same money...
Randy<br /><br />My dream car is never quite finished....<br />I keep running out of money!!
