Heating & Cooling Heating, cooling and air conditioning
Old Mar 23rd, 03, 02:28 PM
pace11 pace11 is offline
Tech Team
Post
in the assemble manual they show ac baffles what are they and where can i get them
Old Mar 23rd, 03, 02:37 PM
JohnZ JohnZ is offline
Team Member
John
Post
What baffles? Where do they go? What section and sheet number are they on in the A.I.M.?
JohnZ
CRG
'69 Z/28 Fathom Green
Old Mar 23rd, 03, 03:17 PM
Tech Team
Post
baffles show on pg 206 (c60 b3) they bolt in front of the dampers on the core support
Old Mar 23rd, 03, 04:25 PM
Mark C Mark C is offline
Mark
Post
They block the airflow around the ends of the core support to force more air through the radiator opening. They were installed in Camaros made after June 12th 1968. By your screen name I will assume your looking for a set for A CONVERTIBLE. They bolt to the Cocktail shakers and wedge against the inside surface of the fenders. The convertible ones are diffent than coues and are extremely rare. There is a set for a coupe on Ebay right now. Coupe ones will not fit a convertible. The only place you will find them is in someones car. They are not reproduced and only very rarely show up on Ebay, or in the for sale section of sites like this. These pieces will run you more than a complete heater delete plate set should you find a set. If you do find a set make sure they have the rubber material on the outer edges. That's not reproduced either.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
My Engine Compartment
Old Mar 23rd, 03, 05:32 PM
Tech Team
Post
thanks mark also i put on new splash (dust)seals and i got one that they say fits under master cylinder the book dont help me can you please
Old Mar 24th, 03, 04:54 AM
stope4 stope4 is offline
Post
Hey Mark I have a set plus one (let's call the one an orphan). Something I could never figure is the set are right and left sides and look really similar. The pointed part on the bottom of the baffle as shown in the 68 assembly manual is not part of these baffles. The orphan baffle is a right and is shaped more similar to the one in the assembly manual (with the point on the bottom). What makes it stranger is the rubber pieces on the set is cut to be shaped exactly like the the orphan. In other words, when I install the rubber on the set and the rubber on the orphan, they look exactly the same. I've never understood this. I hope this makes sense. Also, what is the Ebay Item number so I can see what is being described.
EricE
68 Butternut Yellow
SS Coupe 396/325
Old Mar 24th, 03, 04:22 PM
Mark
Post
Heres the link, took me a while to find it again:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33638
These are for a coupe, you can easily identify them by the X shaped stiffener and that they are rather flat. They will not work in a convertible. Convertible ones have two parallel stiffeners, and are curved to fit around the cocktail shakers.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Old Mar 24th, 03, 05:00 PM
Post
Yes Mack, thats they way the set I have look. Do you know if the baffles for the late 68 look different?
EricE
68 Butternut Yellow
SS Coupe 396/325
Old Mar 24th, 03, 05:05 PM
Cool
Sorry Mack, I meant Mark.
EricE
68 Butternut Yellow
SS Coupe 396/325
