Heating & Cooling Heating, cooling and air conditioning
Old Mar 31st, 03, 05:47 AM
mikestr mikestr is offline
Mike
Question
See this link below.
Are these the infamous flex fans that break and fly off and kill people? Or is this a GM quality unit? I can't tell from the picture.
http://cgi.ebay.com/ebaymotors/ws/eB...408640629&rd=1
Thanks.
1969 Camaro - 468ci/700r4/3.73 - 11sec and drove her home.
Old Mar 31st, 03, 06:51 AM
Rons68 Rons68 is offline
Post
That's not a flex fan; it has a clutch on it.
Old Mar 31st, 03, 08:23 AM
Mike
Post
Thanks Ron, I was referring to the blades, I was under the impression that the blades on it were the ones used on those types of fans. Maybe not. [img]redface.gif[/img]
Old Mar 31st, 03, 12:27 PM
lil_beast_67 lil_beast_67 is offline
Post
I think that what he meant is that flex fans are generally known to break at higher rpms, and since there's a clutch on the fan that won't be as likely. And although it does look like a flex fan, they're called that because they flatten (or flex) out at high rpms, and since they don't flatten out because of the clutch, it's technically not a flex fan anymore.
Maybe I'm just totally wrong though, it wouldn't be the first time [img]graemlins/clonk.gif[/img] .
Beastly 67 in Resto.<br />350 with some goodies.<br /><a href="http://community.webshots.com/user/cdawg67" target="_blank">http://community.webshots.com/user/cdawg67</a>
Old Mar 31st, 03, 12:56 PM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
Post
That's a GM flex-fan used on trucks. They did indeed have a problem with that design but it wasn't as prevelant as the aftermarket performance flex-fans with the alum frame and rivited on stainless blades. Steve Jack has pointed out in the past that there is a more modern version of the flex-fan being produced that won't come apart.
...Dennis
White Wonder
The Nova
Photo Album
www.camaroslimited.com
Old Apr 1st, 03, 07:09 AM
Post
Sorry if I gave an incorrect reply; I thought that fan clutches were only used with stiff non-flex bladed fans.
Old Apr 1st, 03, 08:03 AM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
Post
For the most part you are correct Ron... Your typical speed shop flex fan wouldn't be used with a clutch...
