Heating & Cooling Heating, cooling and air conditioning
Old Apr 1st, 03, 01:38 AM
lil_beast_67 lil_beast_67 is offline
Post
Did a search and didn't come up with much so I'll ask.
I heard some people say that the 19 x 26 is the best size universal griffin aluminum radiator to buy... what else should i know before changing over? Will my fan shroud still work? Will I need to run an electric fan?
My radiator has started to crack in one spot and the thing has never been cleaned so my engine is running hot. I figure that since I plan on modifying the engine anyway, might as well just go to the aluminum now and save myself some trouble later on but I'd like to know what to expect since a lot of you have already done all of this.
Thanks for your replies.
Beastly 67 in Resto.<br />350 with some goodies.<br /><a href="http://community.webshots.com/user/cdawg67" target="_blank">http://community.webshots.com/user/cdawg67</a>
Old Apr 1st, 03, 02:55 AM
Spames Spames is offline
Post
You can fit a larger size if you move your battery to the trunk, but that's the one I have.
You'll need to make custom mounts, and you might be able to use your shroud, but you might neet to modify it, and figure out a way to attach it. The upper radiator hose will work, but the lower one will need some tweaking to make it work.
I bought dual LS1 elec. fans off ebay and trimmed the shroud to fit it to the radiator.
Old Apr 1st, 03, 12:47 PM
Post
how hard is it to make custom mounts?
Old Apr 1st, 03, 02:47 PM
chicane67 chicane67 is offline
Post
Part number 125222. The mounts are pretty easy to make, just dont blow a hole into the tank when you weld'em up!
The only problem with running a core larger than that of 26x19 is that the core cupport blocks the available air to that protion of the radiator. This really isnt a bad thing, but it does you nothing unless the core is exposed to air flow.
Any other recommendation would be to add the 'billet' water neck filler. After taking the cap on and off a few times, like us hotrodders are known for, it will prove its worth.
Old Apr 1st, 03, 05:53 PM
boodlefoof boodlefoof is offline
John
Post
I put in an aluminum radiator (Summit generic brand) and I believe it was 25.75 x 19''. Fit well and making some mounts for it was easy. I had to modify the fan shroud a bit to get it to fit as well. There are some pics on my website under the "summer 2002" section around page 16 or later...
John
click below to read about my '68 Camaro and my other hobbies.
www.geocities.com/boodlefoof
Old Apr 8th, 03, 06:50 PM
rcflier55 rcflier55 is offline
Tech Team
Post
I say go with the electric fan (and no belt driver fan) and 19x26 radiator. I use that set up with a "daily" driver with A/C and about 350hp. My fan has a built in shroud so there is no modifications to make, just hang it with the included hardware and drive it. Just make sure you get a fan with enough cfm output if you decide to go this route.
Randy<br /><br />My dream car is never quite finished....<br />I keep running out of money!!
