Heating & Cooling Heating, cooling and air conditioning
Old Apr 15th, 03, 05:43 AM
GregD GregD is offline
Post
Does anyone have any ideas on how to bypass the heater core? My blower motor doesn't work and I figured it would be easier to just bypass the heater core rather than trying to fix the motor. I drive the car in warm weather only anyway. Do I just cap the intake manifold port? what do I do with the outlet from the water pump?
thanks,
Greg
68 Island Teal
383/700r4
Hotchkis TVS with Global West UCA's
My 68
Old Apr 15th, 03, 06:32 AM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
Post
You can plug both with screw in plugs that replace the current fittings. You can also route a length of heater hose from one fitting to the other. If your core doesn't leak I would leave the hoses attached and not worry about it personally. Even without a fan you can slid the switchs to heat and defrost and it will be better than no defroster at all!!
...Dennis
White Wonder
The Nova
Photo Album
www.camaroslimited.com
Old Apr 15th, 03, 06:46 AM
Post
Ok, I think i'm starting to change my mind a bit. I think I'll try to solve the heater blower motor issue rather than bypassing it. Does anyone have any trouble shooting tips for figuring out why the fan won't run? Are there any common problems with the switches that I can look at? I'd hate to have to pull the blower motor if I don't have to.
thanks,
68 Island Teal
383/700r4
My 68
Old Apr 16th, 03, 11:28 AM
wayner wayner is offline
Post
Try running a wire from the + battery terminal direct to the terminal beside the motor, if it runs its not the motor but between the motor and switch.
