Heating & Cooling Heating, cooling and air conditioning
Old May 25th, 03, 06:10 AM
MStennes's Avatar
MStennes MStennes is offline
Mike
Question
I have decided to go electric fan and a aluminum radiator now come the hard choice who makes a good one I see Summit has a Chev universal how hard is that one to mount the price is right?
69 RS/SS vert tourer, LS7, T56, Baer, Hydrooost, GW, etc, etc,
Needs more cowbell!!!
Old May 25th, 03, 08:40 AM
Mike's67 Mike's67 is offline
Post
I have the SUmmit universal. I welded two pieces of 2" angle iron, each about 3" wide, to the support. This supports the weight. Then I used 1" rubber corks from the hardware store to mount it at four places. I put 2 more 2" rubber corks on the angle iron to reduce shock on the bottom.
I used the 16" Perma cool elec fan. My engine gets real hot in city traffic w/o a shroud though. I'm looking into that now. Hope this helps
67RS-zz4 w/ trickflow heads 276hr cam air gap 780 Pro Systems TexRacing 4spd AGR steering SCAT procars 12 bolt eaton posi 3.73's SSBC all around, TT2's Dakota Digital Painless DSE hinges
http://i231.photobucket.com/albums/e...e/DSC_0104.jpg
Old May 25th, 03, 09:59 AM
MStennes's Avatar
Mike
Post
Im running a 700R4 what did you do for the trans cooler is it in the radiator or are you using a seperate cooler?
Old May 25th, 03, 10:33 AM
cambird68 cambird68 is offline
Steve
Post
I put a 3 core in my Camaro from Rick's. That was the easyest thing I have ever put into my car. It bolted right in the stock holes and took about 10 minutes. My car droped about 30 deg. on the hottest day! Yea, it's not aluminum but, it does the job with a stock look! They even have four row. The best thing about it, it was way cheaper. Cheap, easy, and good looking - heck my wife only holds the good looking portion of that!
Old May 26th, 03, 07:20 AM
paulm paulm is offline
Paul
Post
I don't think that the universal radiators have a trans cooler, so you'll have to buy and mount one in front of the radiator. The only other option is to buy one of their custom radiators that are like factory for $500+.
My 67 HSR Intaked RS Coupe
Best of 1.56 - 11.69@112.95
Old May 26th, 03, 03:35 PM
HOTRODSRJ HOTRODSRJ is offline
Angry
Consider a PRC radiator from www.streetrodstuff.com/Products. I have sent no less than a hundred people over there without complaint. High quality and service for less than $400! Big 1" twin-tubed crossflow is just the ticket.
You can give them exactly what you want for your applications. Email DickZ at dick@streetrodstuff.com and get the ball rolling. They look sweeeeeeeeeet too!
Steve "Jack'stands" Jack
Jack'Stands Tech Forum 1
Jack'Stands Tech Forum 2
