| Team Camaro Tech Current Topic: 75-79 Nova A/C in a 69 Camaro, possible? | ||
| Heating & Cooling Heating, cooling and air conditioning |
Hello all,
I have been doing some searching here, and I seem to have a problem that a lot of you have: The previous owner of my 69 Camaro completely gutted the A/C, from the engine compartment side. I still have the duct work and the heater box that mounts under the dash inside the car. Now the question. Can I use the underhood components from a 75-79 Nova to replace my missing parts. The "suitcase" looks the same, but I haven't been able to measure it for sure. I can find plenty of complete 75-79 systems in local boneyards, so I wouldn't have to mix 69 parts with the newer stuff.
'69 Coupe, Dover White, Black Vinyl Top |
| Sponsored Links | ||
Advertisement | ||
Most likely yes, it will work. I say most likely because I am not sure of the year Nova you need to use. And I say yes because this is exactly what I did on my '67. Same story as you, the firewall was gutted (hacksaw & duct tape) before I got the car.
I've always wanted to put the A/C back into my car and was always greeted with laughter whenever I inquired at automotive recycle yards about 1st gens with A/C. So one day my brother stops over with his Nova. We were futzing around under the hood and I noticed that the A/C looked like is would just bolt up to my '67. As it was his A/C was not operational and he didn't even want it under the hood. Before you knew it fenders were off, A/C and heater systems out, and the Nova was converted to a standard heater system. I even bought him a new dash controller to replace the A/C one in there. It was a perfect job. Then of course the '67 got the A/C parts that work to this day. . . Bob. |
Hey guys,
I just wanted to post a reply to my own message, if someone searched this in the future. I replaced my missing underhood suitcase with one from a '76 Nova. The suitcase is identical. The actual A/C setups are a little different, but 100% originality was not critical for me, so this system works for me and looks like a factory set up. Also, the plenum valve and the kick panel valve on the passenger side from the '76 are the same as the '69. This should open up a whole new source of interchangeable parts for those of us missing the original stuff. From what I've seen, the '75-'79 Novas are plentiful in the graveyards.
| Sponsored Links | |
Advertisement | |
