Convertibles Convertible Q&A's
Old Jan 13th, 02, 06:51 AM
69vert 69vert is offline
Bob
Post
After the last post on these I decided to climb around my 69 and look for this drainage system. I cant seem to find where these drainage holes are and where the water exits the car. I have all of the manuals on the car, but I cant seem to find any information in them.
Bob
Old Jan 13th, 02, 09:12 AM
William William is offline
Post
There is (or should be) a plastic gutter surrounding the top well. It should be visible from the trunk. It diverts water to the sides of the body.
Old Jan 13th, 02, 03:27 PM
KevinW KevinW is offline
Kevin
Post
Bob, I have never seen any diagram on how the water flows out. I do know that it is through small holes that were punched or thin gaps puposely left there between some of the lower metal peices.
A lot of times, they have been gunked up or filled with pine needles and other assorted unpleasant things. No wonder they rusted.
I will have to look closer at mine.
Kevin
69' SS-350 Convert, M20, 3.55 posi. Totally Disassembled & in boxes (I'm working on it!)
69'(Hugger Orange -originally, Burgundy now) Z-21 Convert 327/PG, Driver
Old Jan 13th, 02, 06:32 PM
Kyvox Kyvox is offline
Post
Dump a gallon of water on the roof, and look to see where it comes out at the bottom.
Old Jan 14th, 02, 03:13 PM
Kevin
Post
Bob, there a two throat lozenge sized holes punched in the rocker panel in the qtr well facing outside, aft and front. There is also a gap where the outer wheel house meets the rocker. If both of those get clogged up, water will sit.
The front cowl area drains from a gap between the pieces at the bottom of the cowl well on eihter side of car. This is what get clogged with leaves and fills up the well and rusts the fender bolt and makes the lower rust hole in that area. Hope this helps
Kevin
[This message has been edited by KevinW (edited 01-14-2002).]
Old Jan 14th, 02, 05:03 PM
Bob
Post
Thanks for the help. I will scour my car next weekend and look for these holes and try to clear them.
Bob
Old Jan 15th, 02, 05:05 AM
Franken122 Franken122 is offline
Tech Team
Post
Kevin, (or anybody else...)
Any chance you could take a digital pic of the front and back drainage areas to show the holes and either post them or offer to email them???
I'm removing rusted rockers from a 67 convertible, and needless to say the front and back ends were filled w/ rust chips, even the front cowl. Last thing I want to do is zap it all back together and not put drainage in.
Funny you should mention pine needles above. Mine was stuffed in some of the bad rust holes. Even found some kinda mouse nest in the rusted out heater box. It ran great for a few years when I bought it (before I took it down to parade rest), I think the owner before me just had a little permanent hitchhiker living in his garage.
-Jeff
Old Jan 15th, 02, 07:32 AM
Kevin
Post
I will try to take some pics. stay tuned!
Old Jan 15th, 02, 04:22 PM
68ragtop 68ragtop is offline
Post
Pine needles are awful, I've been told they're acidic (although slightly) and add insult to injury
Any one else hear of this??
Old Jan 16th, 02, 03:37 AM
Kevin
Post
Took the pics last night, but had trouble uploading. I will try again tonight.
Old Jan 16th, 02, 12:57 PM
Kevin
Post
Here is the front under the cowl
the forward hole in qtr window well
and the rearward hole and gap between wheel well. Since the qtr and wheel well have been replaced, I'm not sure if the gap is factory.
hope that helps. Kevin
Old Jan 17th, 02, 02:10 AM
RickD RickD is offline
Team Member
Post
Great pics, Kevin. I'm afraid to look under my car.
However, since my car is at the 'welders' for rust repair, it is an opportunity. How I hate that word.
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips.
Old Dec 26th, 03, 11:26 AM
G Gagnier G Gagnier is offline
Post
Gentlemen, I found chevys way of draining the water not only primative but causes rusting out of floor pans. I put some funnels and curled them under the trough and attached hoes exiting my rear wheel wells , this works great Garry
Old Jan 3rd, 04, 12:18 PM
Steve W Steve W is offline
Post
it would be great to see some pics of the "funnel"
Steve W
1968 Camaro Convertible
1966 GTO Convertible
1995 Harley Road King
"You can't always get what you waaant..."
Steve's 68 Camaro
