| Team Camaro Tech Current Topic: Convertible Header Finish | ||
| Convertibles Convertible Q&A's |
Can any one tell me if they know of any one or any way to get the correct finish on the convertible header trim pieces. In 67 and early 68 they were bright chrome but later they were a satin finish. I am looking to refinish mine but I would like to get the correct satin finish on them. Any ideas?
On my '69 I sprayed it with Krylon Dull Aluminum, let it dry thoroughly, then rubbed it with 0000 steel wool. 14 years later it still looks perfect. Don't know if it's absolutely correct - probably not - but it's dang close.
You could bead blast it to a satin finish.
Ron The “Junk Yard Dog” An exercise in interchangeability on a Well optioned 67 SS 350 vert. |
That is essentially what the factory did. When those moldings were still available from The General (showing my age...) they usually still had the masking tape on them.
So by rechroming the header and then bead blasting it will give the correct satin finish?
Were was the location of the masking tape, or was the whole header satin finish |
The front half was mask off and the back was the satin finish.
Does any one have a picture that shows the correct finish and mask off area?
They were not bead blasted - they painted over the chrome.
You can find those pcs. NOS.
They run about 100 each side. |
So what is it were they painted or bead blasted can anyone definitly confirm the correct finish.
And if they are available nos were can you get a set? |
#11
It is a silver color with a strip of chrome for the side moldings to attach.
68 and 69 Part #'s 8714979 (left) and 8714978 (right) 68's and 69 conv.'s have the same windshield header moldings. 67's were different. NOS Part # 8714979 is 145.00. NOS part # 8714978 is out of stock. |
