Convertibles Convertible Q&A's
Old Mar 29th, 03, 05:43 PM
Paul 69 Paul 69 is offline
Tech Team
Post
My power top used to work fine and last fall started tripping the breaker while putting the top up.The top goes about half way up when it tripps,then in about two minutes(auto reset breaker)I can put it all the way up.I just started looking into it.The fluid level is ok,I lubricated all pivot points,and I disconected the lift cylinders so I could move the top manually and check for binding.It dosn't seem to be binding.I suspect the pump motor is going bad and drawing too much current but I'm not sure.I haven't checked current yet.Has anyone had a similar problem.I hate to guess,a new pump is about $190. Thanks
69 SS/RS Convert.
Old Mar 29th, 03, 06:25 PM
Gary Dorion Gary Dorion is offline
Post
IMO, the relay could be just getting old. I had to replace my horn relay, and when I opened it up it was a mess.
82 Delorean.
69 Camaro convertible,fully restored, well almost.
Old Mar 30th, 03, 06:02 PM
69vert 69vert is offline
Bob
Post
I agree with Gary...Go to Kragen and pick up a new 30A Self resetting Circuit breaker...give it a try. $3 bucks is better that $190
Bob
