Convertibles Convertible Q&A's
Old Mar 22nd, 03, 07:33 PM
69vert 69vert is offline
Bob
Post
I am trying to remove the old rotted top off of my 69 convertible. I want to sand and paint the frame. I cant seem to figure out how to remove the tack strip (see picture) How is it held in place? I dont see any screws or rivets. Any help would be appreciated.
Bob
Old Mar 23rd, 03, 03:29 AM
Mat Klemp Mat Klemp is offline
Team Member
Post
This is by my old memory. On the front bow there are small triangular tabs that hold it in. in the rear, I believe the tack strip is pinched in the metal channel. Not easy to remove and replace.
TTFN
Mat
SSCARGO
Old Mar 24th, 03, 07:49 AM
coach420 coach420 is offline
Talking
I scraped it out with a large screwdriver.
Old Mar 24th, 03, 04:46 PM
Geezer Geezer is offline
Post
I did the same as coach 420 then regretted it after I found out how much tack strips cost to replace…
Ron
The “Junk Yard Dog”
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Old Mar 24th, 03, 09:41 PM
Vintage 68's Avatar
John
Post
I have to agree with Geezer on this one!
If the old one is servicable I would leave it alone and paint over and around it. They are expensive and a real PITA to reinstall correctly. It's almost impossible to get the chanel opened up to accept the new one and then get it pinched down evenly again. I was really affraid I was going to FU the top bow during the work.
1968 Convertible
Some trucks
Other things - some of which float ...
Eagles may soar - but Guinea's don't get sucked into jet engines ...
It's never to late - okay, maybe now it is ...
WE NEED MORE COW BELL !!!
Old Mar 25th, 03, 03:43 AM
CrossRamZ11 CrossRamZ11 is offline
Post
Bob,
Tack strips can take alot of abuse and still be more than usable for a new top. My suggestion would be to take a small screwdriver, pry out all of the old staples, then paint right over it. This is what I did with my top frame (although it was out of the car) Unless the strip is completely rotted or destroyed, you will not gain anything by pulling it out.
Old Mar 25th, 03, 07:35 AM
Post
I think Bob is referring to the material that is in the rear bow, not the strip of metal that is screwed into the body of the car near the well liner. The material in the bow is a composition that is typically dried out and crumbling from use and age. Replacement material is inexpensive and can be pushed down in the channel and glued in place with weatherstripping adhesive. No big deal.
Old Mar 26th, 03, 05:35 PM
Bob
Post
Yes I was talking about the material in the channel. Where can I find that material? I dont see it listed in any catalog.
Bob
Old Mar 27th, 03, 07:05 AM
Vintage 68's Avatar
John
Post
Try www.convertibleparts.com
I don't think I remember them being listed on the web site, but they carry them and about every other rag-top part you could need.
1968 Convertible
Some trucks
Old Mar 27th, 03, 08:03 AM
Cool
Most of the catalogs have it. Rick's First Generation calls it "convertible top frame tack strip". You order it by the foot. I recall that the 5/8" inch width was correct but check with them before ordering. You'll need to double layer it since it is thin, so order twice the length.
