Convertibles Convertible Q&A's
Old Jan 9th, 03, 09:50 AM
Kens68 Kens68 is offline
Tech Team
Default
Little help for a convertible! I am replacing a cracked hydraulic hose to my cylinders and pump assembly and noticed that the o-rings are in bad shape. There are 2 small o-rings on each cylinder where the hydraulic hoses attach and 2 slightly larger 0-rings on the pump assembly where the hoses attach to it. I checked all the automotive shops for O-rings, they only have the round ones, the kind I am looking for are square O-rings if that makes sense (I can take a picture of them if it would help identify a source). Any idea where I may be able to get some replacements, they were not provided with the new hose kit I got. Thanks, Ken
Old Jan 9th, 03, 09:58 AM
brichead brichead is offline
Default
Try a bearing house. I believe what you are looking for is called a quad-ring. Or you can get them from anyone who specializes in hydraulic seals & fittings. They will just need the O.D. & thickness of the material.
Brichead
Old Jan 9th, 03, 10:28 AM
Jeff H Jeff H is offline
Default
I had them replaced by the local shop that specialized in hydraulics. They told me that you can't really rebuild the cylinders and putting in new o-rings is the only solution. They had so many different rings, he was able to replace them in less than 5 minutes for me.
Jeff H - Hugger Orange 69 Z28, original factory JL8 brakes, cross-ram & GM fiberglass hood, TI setup, heater and radio delete, Stahl headers, Minilite wheels - being restored - 87 Toyota 4Runner SR5 Turbo
