| Team Camaro Tech Current Topic: Convertible Sub Frame Connectors Information Web Site | ||
| Convertibles Convertible Q&A's |
We have discussed this topic so much I decided to create a web page on my site to help out everyone.
I will add more information and images as time alows but for now this should provide the only three options that I know of for us first gen Convertible owners. Please check it out and provide me some feedback guys. First Gen Convertible Sub Frame Connector Informatio Web Site
69 RS Convertible Camaro, 350/350. Orignal red with black top and interior. Hotchkis suspension. |
If anyone wants to submit more pics or information please email me and I will add it to this page.
Thanks; Great pictures and explanation.
I have a fourth idea to increase body stiffness, which I will be experimenting with in the next few weeks. It involves using epoxy based expanding foam in every body 'box' section I can find. I will also fill the rocker panels with 2-part urethane foam; it is not quite as rigid but is lighter. Hopefully I can increase the body stiffness without the appearance issues of the other methods. I will need to do a comparison with another convertible that has the sub frame connectors to determine how effective the treatment is. Hopefully someone in the Los Angeles area can help me with the comparison. |
Hey Rick, not sure if we're talking about the same thing, but the previous owner of my car sprayed foam into one of the rockers.
It acts like a sponge and keeps moisture in there. I dug most of it out and now my convertible drains correctly.
68 Camaro ragtop, original 327, CCHE268, Dart Iron Eagle heads, Holley 650, Doug Thorleys w/Magnaflows & 2.5" exhaust, Muncie M20, 3.08 posi, 4-wheel discs 2010 Camaro 2LT RS, Red Jewell Tintcoat, M6, White hockeys, Beige leather, Sunroof |
How many of you still use the "X-brace" along with the subframe connectors? I've been told by a few once you put sub-frames on, the x-brace can be removed without sacrificing anything.
Any thoughts? I use the Global West subframes for the Convertible. |
Ileft mine in place but shimmed down to get the pipes in, I'm using Global West
69 RS/SS vert tourer, LS7, T56, Baer, Hydrooost, GW, etc, etc, Needs more cowbell!!! |
I left my X-brace IN. I don't think the subframe connectors are supposed to replace anything, rather they help reinforce what's already there.
I know some guys who booted the X brace in favor of a bigger exhaust...and then went back and found a way to shim the X Brace and put it back in, because the car is almost un-driveable without it! IMO, leave EVERYTHING in the car and add sfc's...unless you're installing a full-on roll cage.
Steve W 1968 Camaro Convertible 1966 GTO Convertible 1995 Harley Road King "You can't always get what you waaant..." Steve's 68 Camaro |
Nice website. I think it will be a big help to those considering SFC's. I will see if I can get a good pic of the bump in the rear seat area carpet caused by the DS&E SFC's for your site. This site just gets better and better. bob
<a href="http://www.homepage.mac.com/bspears/Menu10.html" target="_blank">69mscle</a><br /><a href="http://www.popularhotrodding.com/features/0311phr_spears/" target="_blank">My Popular Hotrodding Article</a> |
I am buying a Convertible this week end and I was looking for this very thing and VOILA!! here it is . Excellent, most Excellent. Bob, you have one of the best looking and sitting 69 Verts I have ever seen. I would not sell that car ever. [img]graemlins/thumbsup.gif[/img]
[ 04-02-2004, 03:37 PM: Message edited by: ummgawa ] |
#11
Glad I could help guys.
And thanks Bob for offering more pics. I just quit my job and start at Nextel next week. My email address has changed. My new email is john@ragersworld.com.
#12
I Have a 68' vert with a 454, turbo 400 and 12 bolt posi. I've never had any problems with the body shake or anything like that. I do have the x-brace installed but no sfc's. I keep reading about the body flex. What kind of power levels are we talking about before you need sfc's? 300-400 hp. or more? Maybe i should consider a small block.
JD67-69 |
#13
I have done alot of research on this subject and tried to put it in a basic mechanical model. While the Camaros are pretty good, I recently did a 70 Mustang convertible which was terrible and had to have subframes put in. The Ford's are weaker.
The way I relate the function of the crossplate is this.....take your hand and spread out your thumb and fingers as far and wide as you can horizontally. Pretend that your thumb and little finger represents the cowl from side to side. Now simply holding your arm still and ridgid in front of you, rotate your hand like you are fluttering it in front of you (like demonstrating an airplane move). Your hand move easily thru the rotation. Now grab your wrist/lower part of your hand with your other hand and wrap your fingers around your wrist where it meets the hand... and try the same rotation. Even tho your other hand is a stabilizing effect, the real stabilizing is done by holding the two wrist bones together and this really adds rigidity to the whole mechanism. Your frame at that point is exactly the same. With little side to side or "rotation" axis support it will easily "resonnate" and with the X member it stabilizes this connection tremendously. |
#15
Thought I would add my $0.02. I left the cross plate in and shimmed it to clear new 2 1/2" exhaust. Left the shakers in also. But really made the difference in "feel" was the Competition Engineering subframe connectors. We notched the factory frame braces(side to tunnel brace) then welded the connectors to the frame on both ends and at the notch. Made the car feel incredibly solid and responsive.
