Convertibles Convertible Q&A's
Old Mar 31st, 04, 02:02 PM
69X55Convertible 69X55Convertible is offline
Post
is there anyway to put chambered exhaust on a convertible? ive heard you can't, but it seems that you should be able to.----Alex
Old Mar 31st, 04, 03:00 PM
Mark C Mark C is offline
Mark
Post
Yes you can. I've got it on mine, you just have to be VERY carefull when you install it to line it up just right so you can get inside the trans tunnel above the convertible underbody brace. Install everything loose and adjust it the way you want with the brace installed befroe you tighten down the clamps. If your not carefull the pipes will rattle on either the brace or the floor of the tunnel. You might have to shim the brace down a little with washers. I've got 3 washers under the front of my brace, and the pipes just clear.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
My Engine Compartment
