Convertibles Convertible Q&A's
Old Apr 4th, 04, 06:35 PM
MrAbody MrAbody is offline
Post
Ok, the power top motor on mounts on 3 rubber 'grommets' that press into the legs and the mount points on the body. Whats the trick to replace these? There is no room in there to push those rubber mounts into the into their places. It seems impossible to do once the motor has been removed. Anyone know the trick to this?
Thanks!
Old Apr 4th, 04, 08:17 PM
angelglo angelglo is offline
angel
Post
there should be holes on top of the gromet. use something to push them in. but, and a BIG BUT, dont use anything sharp that will puncture the gromet. use something dull. by doing it this way, you stretch it out and make it thin enough to slip in. speaking of slipping in, use something to lubricate it. when i did mine, the closest thing i had to lubricateit was my own spit but it worked.
good luck
angel
