Convertibles Convertible Q&A's
Old May 7th, 04, 12:24 PM
68 Convert 68 Convert is offline
Question
When I bought my car, it had dual s on it, but was missing the x brace. I bought a x brace and want to puyt a new exhaust system in. What are your suggestions?
Thanks again
John
Old May 9th, 04, 05:14 PM
MytMini MytMini is offline
Unhappy
Someone on here got one of the Flowmaster systems to work with just a 1/4 inch shim on the x-brace. I can't remember who now, but maybe they will chime in.
Donald
68 Camaro convertible (resto on hold - last updated 12/31/07)
Old May 10th, 04, 03:44 AM
rs1968ss's Avatar
rs1968ss rs1968ss is offline
Randy
Post
I had a custom system done at a local shop. 2.5" was the max that we could fit but I have heard of people putting 3" on.
-Randy
The White Rat
2003 Silverado SS
Old May 10th, 04, 11:41 AM
jrager jrager is offline
Post
It depends on if you want to go stock or after market/performance.
I had a stock system on and replaced it with the Flowmaster dual set up. I like it allot but make sure you take your car to a good shop that understands exactly what you want or do it yourself.
I had to have my shop install it twice because they did not even consider the X brace. They also installed the emergency break cross over cable over the pipes instead of under.
Just tell them that you would like the system installed with the X brace in use.
My X brace needs a spacer in the front but none in the back. If the shop took enough time I think they could have mounted it better with no spacer needed for the x brace.
Because I have sub frame connectors in I have not put the x brace back in yet.
One other member (Bob Spears) had his system mounted without spacers and was able to use the X brace. I think he just went to a better shop.
69 RS Convertible Camaro, 350/350. Orignal red with black top and interior. Hotchkis suspension.
Old May 10th, 04, 02:02 PM
Angry
Thanks for the replies. Much appreciated.I live in a small town of 6000 and the only muffler shop in town has alot to be desired. I guess I will put on the trailer and drive 120 miles to GET R DONE.
Thanks again!
Old May 11th, 04, 11:04 AM
bspears bspears is offline
Post
In my 69 vert we installed the Flowmaster American thunder system with 2.5 inch pipe under the xbrace with only 1/4 inch shims. The fitment was nice. I am behind a firewall here so I can't link you to pics but if you go to www.homepage.mac.com/bspears and browse around you can find all sorts of pics of the exhaust system.
good luck with your project
bob
ps.....there is a Quicktime sound file of the exhaust system at idle if you are interested
<a href="http://www.homepage.mac.com/bspears/Menu10.html" target="_blank">69mscle</a><br /><a href="http://www.popularhotrodding.com/features/0311phr_spears/" target="_blank">My Popular Hotrodding Article</a>
Old May 11th, 04, 03:36 PM
Unhappy
Well, I am reassembling my car and had Dynomax headers on it that fit great. Well, I pulled the motor etc a while ago, put in a ZZ4 and put the engine in with new Energy Suspension poly motor mounts. I test fitted the headers and the drivers side fits great. The passenger side hits the floor pan. Is there anything I can do besides bend up my floor pan?
Thank you [img]graemlins/sad.gif[/img]
Old May 12th, 04, 03:40 AM
Jeff H Jeff H is offline
Post
The passenger side header was hitting the floor pan on my 68 as well. It turned out the transmisison crossmember was holding the transmission up too high and when I put the custom crossmember in, it lowered back down and the head has clearance now. Maybe yours trans mount bushing is too thick. Or the motor mounts are sitting too high. If it fit before, it should fit now.
Jeff H
69 Z28 Hugger Orange original factory JL8 brakes, cross-ram & GM fiberglass hood, TI setup, heater and radio delete, Stahl headers, Minilite wheels - being restored
00 Camaro SS daily beater
Old May 13th, 04, 04:14 PM
Sporter Sporter is offline
Post
3 inch Dr Gas tandem x-pipe with 3 inch mufflers.
Modified cross brace.
Tight fit, but it does fit.
Old May 14th, 04, 04:18 AM
Post
Sporter,
Great pics!!!!
Also a great look at how to space out the X brace.
Thanks alot.
Old May 28th, 04, 05:27 PM
Jon69RagTop Jon69RagTop is offline
Post
I must say the exhaust I installed looks identical to the one pictured above. I too used a Dr. Gas, 3" In, and Out to a 2 1/2".
Instead of shimming down my x-brace, I had already installed Globasl West Sub Frame Connectors, so I made a new X-Brace that actually fits up into the tunnel, above the exhaust. I felt shimming down the x-brace was a little to low, not to mention if you ever drove over something, I didn't want to rip off the floorpans. At least the exhaust now which is the lowest point can't snag on anything. The x-brace is very similar to the one they installed on the White Convertible at Year One. They did something very similar.
If anyone would like to post some pictures fro me, I could email them to you so they could be posted. I'm not up to speed on the proscess, Sorry.
Old May 30th, 04, 11:08 AM
BPOS BPOS is offline
Al
Post
And here they are. Thanks, Jon.
[ 05-30-2004, 01:46 PM: Message edited by: BPOS ]
Old May 30th, 04, 07:41 PM
Mark .L.W. Mark .L.W. is offline
Post
I'm also going 3 inch on my convert , I will be using borla's , I will be running 3 inch over the axle also what should I run centre out or offset out of the mufflers , what would give the most clearance or does it matter .
Mark .
pictures can be viewed at http://photobucket.com/albums/b247/mark69rs/
Old May 31st, 04, 05:30 AM
Post
My Flowmasters are side inlet, center outlet, and I think it works well. 50's are what I run.
Try the link below to my web page that shows more descriptions and photos of my exhaust.
http://home.earthlink.net/~jcniez/index.html
Old May 31st, 04, 02:18 PM
Unhappy
I checked my rear trans mount and it is the same as a stock rubber one, same with the motor mounts. I am thinking the guy who put my floor pans in put it in to low. Unfortunately, he no live here anymore. I dont want to beat my floor pan in. I am looking at going with stock manifolds. Any thoughts?
John
