| Team Camaro Tech Current Topic: Windshield/A Pillar weather stripping on a 69 | ||
| Convertibles Convertible Q&A's |
How does the Windshield/A Pillar weather stripping
attach? Mine is missing a chunk up at the top and I see a screw, but if the chunk was not missing i would not even be able to get to that screw.
69rad 69 350 4spd. Convertible Cowl Inducted LT-1 with full Instrumentation |
the weather stripping has a hole all the way through. if your weather stripping was intact, ;you would still be able to see the screw if you looked inside the hole
angel |
Are you talking about the weatherstripping that goes along the roofrail and seals the window on the door? That weatherstrip is pressed in a channel and glued. The channel is chrome and screws to the body along the roofrail and has the blow out clips attached to it. This is probably the hardest NOS piece of weatherstrip to find nowadays. They do make repo weatherstrips for this.
Team Camaro Gold Member #14 1967 Camaro RS/z28 - one of 602 made - SOLD 1969 Camaro RS/SS L48 4 speed 1974 Camaro LT-Z/28 4 speed 33K orig 1984 Camaro z/28 LG4 auto 1971 ElCamino SS454 -Tremec 5 spd |
Since this a convert section, I assume you are talking about a convertibles weather strip [img]smile.gif[/img]
The weather strip is glued to the channel, the channel is screwed first to the piller with the stainless A-piller cover underneath. You are probably seeing the channel to piller screw head. |
Yes it's a convertible.
Is the wire mesh I, see part of the weather stripping?
kevin,
i dont have the screw under the w/stripping. on both my verts, 68 and 69, they are like the one pictured. the 69 is a repro but the 68 i believe could posibly be original and it too does have the wire mesh. look in the album under pinchweld http://community.webshots.com/user/angelglozano angel |
Angel, I do not see the pic you are refering to in your album. I will try to get a pic tonight of mine and post it.
Whoops I didnt see what section it was in. [img]redface.gif[/img]
I just go to the todays active topics link at the top of the forum page. sorry
Okay, You guys got me way confused.
Can you help me with my situation??
69rad, We will get there, have faith [img]smile.gif[/img]
We are talking about this section of the windshield, right? Here is what is underneath You can see the screw holes in the support. Does the screw that you can see, match up with one if the holes shown in pic? Also, the mesh you see, might just be re-enforcement molded inside the weatherstrip. |
#11
Yes, That's IT!
My weather strip is broken off even with the top end of the metal channel down almost to the screw that is what caused the mesh to be seen. Is there 4 screws or 2? In the pic I see the 2 holes that are raised and 2 that are either flush or recessed. So the screws hold the channel that that the weather strip is glued to? Or does the weather strip come with the metal channel?
