Camaro Tech General Tech Area
Old Jan 16th, 04, 05:03 PM
Gary L's Avatar
Gary L Gary L is offline
Gold Member
"Tri-Tip"
Post
I need to replace my incorrect M21 in my stock '69 Z. For strictly a street car is the M20 or M21 a better choice. I need opinions. Thanks,
Gary
Gary, SIM TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original.
http://www.camaros.net/showroom/data/500/DSC00005.JPG
http://www.camaros.net/forums/image....3&type=profile
http://www.camaros.net/showroom/show...0&ppuser=11189
Old Jan 16th, 04, 05:35 PM
William William is offline
Post
With 3.73s the M20 is better.
William
CRG www.camaros.org
Old Jan 16th, 04, 05:57 PM
Scooby Doo Scooby Doo is offline
Post
Huh? No, the m20 is a wide ratio tranny and combines well with higher gear ratios.
The m21 is a close ratio tranny and combines better with low gear ratios.
You want a m21 w/ 3.73's.
Dave
1967 Camaro RS/SS 396
1966 Mustang Convertible PROJECT
Old Jan 16th, 04, 06:24 PM
Gary L's Avatar
Gold Member
"Tri-Tip"
Post
I know that the M20's lower 1st gear gets the car moving easier, but what other advantages are there? The M21 close gear ratios can keep the engine running in the power band. What other advantages are there? Thanks.
Old Jan 16th, 04, 06:29 PM
COPO PETE COPO PETE is offline
Post
M20... without a doubt!
Peter
Old Jan 17th, 04, 12:07 AM
Post
http://www.interlog.com/~muncie/designop.html
Old Jan 17th, 04, 02:29 AM
ckaram's Avatar
ckaram ckaram is offline
Chris
Post
You need to tell everyone your rearend. Then, take Scoob's advice depending on whether your gears are low or high.
68 Camaro ragtop, original 327, CCHE268, Dart Iron Eagle heads, Holley 650, Doug Thorleys w/Magnaflows & 2.5" exhaust, Muncie M20, 3.08 posi, 4-wheel discs
2010 Camaro 2LT RS, Red Jewell Tintcoat, M6, White hockeys, Beige leather, Sunroof
Old Jan 17th, 04, 03:37 AM
69Z28 69Z28 is offline
Post
There was a 67 M21 in my 69 Z when I first bought it with 4.10's in the rear and 27" tall tires. The car shook like heck when the clutch was released. I read some post's about using the M20 vs M21. So I found an M20 that was closer to my Z's build date and istalled it. Really made a big, big difference in how the car launched. The shake was completely gone and the car moves alot quicker when I release the clutch. Since then I have replaced the Weld wheels and 27" tires that were on it with rally wheels and 26" tires, removed the Comp. Eng. traction bars with J-bolts and my Z is much smoother on take off.
GARY
MY CAR...
06A 1969 Camaro Z/28, X33D80, Cortez Silver, Black Vinyl Top, Black Stripes, Black Standard Interior, Console w/gauges, & tach. Non original drive train. DZ302, M20, 11-68 12 bolt 4.10's.
Old Jan 17th, 04, 05:29 AM
Gary L's Avatar
Gold Member
"Tri-Tip"
Post
My car has 3.73's.
Copo Pete: Please elaborate.
Old Jan 17th, 04, 07:19 AM
Post
If you replace your M21 with a M20, you will think you have added about 50 horse to the motor. The difference is unbelieveable. I run a M20 with 4:10's in both my Chevelle and Nova. The Chevelle picked up 2 tenths in the 1/4 mile with no other change than the tranny. You will NOT be sorry! The car will be much more enjoyable to drive. Especially in the city with lots of stop lights!
Peter
Old Jan 17th, 04, 08:14 AM
Gary L's Avatar
Gold Member
"Tri-Tip"
Post
Thats what I was looking for. I know the close ratio is "more cool" to drive, but what is more pratical for the street. What was the % of '69 Z's that got M20's?
Old Jan 17th, 04, 10:01 AM
ckaram's Avatar
Chris
Post
The point Scooby is making is that you may find yourself having to shift out of 1st gear too soon with the M20 and rearend at 3.73 and numerically higher. You may not like that for everyday driving (think "creeper" gear).
Then again, if you're on the strip often like COPO says, you'll like the pickup you'll get in ET. It's all about how you'll use your car most.
I scanned the net for a short while and didn't see any production numbers on Z's by transmission type. Someone on this site probably knows.
Old Jan 17th, 04, 06:50 PM
ToocoolZ28 ToocoolZ28 is offline
Ron
Post
Nope, compare my 95 Z28 6 speed with 2.62 first gear and 4.10 rear gears, not like a creeper gear at all. 1st gear is like a monster out of the hole. It's my everyday driver and I've put 182,000 miles on it since 95.
Go with the M20, you'll love the 2.52 first gear.
Ron
70 Chevelle SS396 (427) Tremec 5 speed
95 Z28 Convertible T56
Aces 3081, TC #54 Gold
Old Jan 18th, 04, 04:05 AM
ckaram's Avatar
Chris
Talking
Chevy wouldn't have made the volume of Z's with the M20 if there wasn't some value to it drive-wise...
To each his own [img]graemlins/beers.gif[/img]
