Camaro Tech General Tech Area
Old Jan 16th, 04, 06:33 PM
Todd Miller Todd Miller is offline
Tech Team
Post
Getting ready to repl. the incorrect saginaw trans in my very correct other wise 69 z/28. Any thoughts on wheither it is worth the expense to find the correct dated m-21 for my car or just find a good used m-21 and put in. I want to keep the value and correctness of the car as much as possible but not sure is it worth the extra 3-500 to find the correct date coded trans???
Old Jan 16th, 04, 08:12 PM
Bob Jenkins Bob Jenkins is offline
Lightbulb
Because your car is pretty close to correct, I would probably spend the extra $ now. As you can see from looking at prices, parts are getting higher all the time.... [img]graemlins/beers.gif[/img]
'69 SS 396/375hp L78 M21 3.73 Fathom green/medium green interior<P>See a picture of my Camaro here:<P><A HREF="http://temp.corvetteforum.net/c3/1970corvette//view.jpg" TARGET=_blank>http://temp.corvetteforum.net/c3/1970corvette//view.jpg</A>
Old Jan 17th, 04, 09:53 AM
novaderrik novaderrik is offline
Post
ahh, come on- get a Tremac 5 speed and do some updating to technology they surely would have used had they had it when the car was built...
you don't plan sincerity.
you have to make it up on the spot.
my 1974 Monte Carlo & 84 Turbo Buick
86 Monte SS that should probably be crushed
Old Jan 17th, 04, 12:11 PM
Gary L's Avatar
Gary L Gary L is offline
Gold Member
"Tri-Tip"
Post
Todd:
I am going thru something similar on the thread below. Go for the original with as close a date you can find. They are out there. The value of a Z is the correct components.
novaderrik:
Wouldn't the rear gears need to be much higher than 3.73 with a 3.xx something first gear in the Tremec?
http:r the//www.camaros.net/forum/ultimatebb.php?ubb=get_topic;f=24;t=000016
Gary, SIM TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original.
http://www.camaros.net/showroom/data/500/DSC00005.JPG
http://www.camaros.net/forums/image....3&type=profile
http://www.camaros.net/showroom/show...0&ppuser=11189
