| Team Camaro Tech Current Topic: 69 windshield date coding | ||
| Camaro Tech General Tech Area For best results use specific forums |
I want to replace the windshield on my 69 convertible (03D build). Cannot find what the correct etching for the windshield shoulld be (LOF, style, etc). Been on Camaro Research Group website and further confused the issue. Any thoughts? Thanks
Hello , My Documented 06A RSZ28 has the following info on the ORIGINAL Windshield-
SHADED SOFT-RAY SAFETY LOF PLATE ASI LV LAMINATED DOT 15 MA This is how it appears except the LOF has a Logo around it. Hope this helps.
1994 Lumina Z34, 2655lbs. 446" Rocket Small Block, Brodix Canted Valve, Sheet metal intake, lenco 5 speed, 8.21/167 Best. GM Canada Documented Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973. |
Jeff there is some discussion of glass at www.camaros.org and also use the 'search' button at the top right corner and type in 'glass' or 'windshield' and you should find alot of discusson on what to look for.
Welcome to Team Camaro as well, [img]graemlins/beers.gif[/img]
Click..is Jim..69RS-LM1 350/255 - 700r 4speed auto. "There will come a time when you believe everything is finished, That will be the beginning." Louis L'Amour Our Camaro Webpage Photos for viewing Learn How To Post Pics here |
Any of the repro parts houses can get what you need. They basically come from one manufacturer. They know what the etching should be. You need to give them the date you need. Thats all.
http://www.pilkington.com/the+americ...cs/default.htm
Gary, SIM TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original. http://www.camaros.net/showroom/data/500/DSC00005.JPG http://www.camaros.net/forums/image....3&type=profile http://www.camaros.net/showroom/show...0&ppuser=11189 |
Try Auto City Classics,Isanti Mn.phone 763-444-5880/web site is autocity@worldnet.att.net.
I bought my windshield and back glass there, and they were $150 cheaper than Rick's. They know how the markings should look. You can either provide the date code, or you can give them your build date, and they will do it for you. Look at the article on CRG for date decoding. YOu should probably use the code from other glass on the car, if you know it to be original. By the way, it comes in a large palet box, with the box for the glass well padded inside. YOu have to either ship it to a business, or go pick it up yourself at the terminal. They won't tell you the brand, but it is Pilkington (they bought LOF) |
