Camaro Tech General Tech Area
Old Jan 28th, 04, 06:24 PM
crossram crossram is offline
Tech Team
Angry
I have a 69 RS SS convert with fiber optics that I did not remove*&%$# restorer bailed on me!! Is there a schematic available for the 69. I see one cable goes to the rear license plate light where do the others connect to the tail lights?? I see a slot at the bottem of the RS tail light but no hole???
The front has a cable to each marker, thats fine, and then is there is one to the high beam Is there a hole or location for it? Only one fender fiber indicator has a cable to the high beam??
Kinda cool it does work though just need routing information.
[img]graemlins/beers.gif[/img]
Barry<br />70 1/2 RS Z-28<br />69 Z-28 Crossram<br />69 RS SS 396 Convert<br />69 RS ProStreet 638 G.M.<br />70 LS6 Chevelle<br />66 427 425hp Vette Conv<br />02 Camaro Pro Stock/Street
Old Jan 29th, 04, 02:53 AM
69ss350 69ss350 is offline
Angry
Check out the Camaro Assembly manual under option code U46. It explains everything.
For the headlamps, there is a hole right in the middle of the plug that attaches to the headlamp itself.
The fiber for the rear lights (outer-most only) plugs into a round slot molded into the light socket.
Mike
69 Camaro Z27
