horn relay wiring - Team Camaro Tech
Camaro Tech General Tech Area
Old Jul 30th, 04, 10:25 AM
giffholmes giffholmes is offline
Question
Confused as to how to properly wire horn relay. I've already melted the pink/black key buzzer wire in the steering column!! Fortunately I had a spare column harness.
There are three terminals on the bottom of the relay. Two of the terminals read 12 volts with key off. I believe the horns (dark green) should be on a hot terminal. But what about pink/black and the black wires.
Could someone please explain?
tia
Giff
1969 Camaro coupe -project
