| Team Camaro Tech Current Topic: Need pic of brake line plumbing on 69 w/ frt. disc | ||
| Restoration Corner Where originality comes first |
I'm looking for a pic of the brake lines going from the M/C to the proportioning valve and then to the distribution block on a 69.
That size wrench do the fittings on the M/C and the distribution valve take? The fittings on my prop. valve take a 7/16" Thanks for the info
69rad 69 350 4spd. Convertible Cowl Inducted LT-1 with full Instrumentation |
These should help:
http://img18.photobucket.com/albums/...icture_003.jpg http://img18.photobucket.com/albums/...icture_002.jpg http://img18.photobucket.com/albums/...icture_001.jpg Can't remember wrench sizes off the top of my hear, but does 9/16" sound right?
69 Pace Car - 9,300 Original Miles 69 SS 350, Lemans Blue, 350/300, TH350 69 Plain Jane, 17,000 miles, 307/PG 2004 Silverado LT 2500HD Crew Cab Short Bed Duramax Diesel - I8AFORD |
Perfect!!
Alot better than the first reply I got from the same post in the Brake and Suspension forum. Thanks
Huh???
Team Camaro Gold Member #14 1967 Camaro RS/z28 - one of 602 made - SOLD 1969 Camaro RS/SS L48 4 speed 1974 Camaro LT-Z/28 4 speed 33K orig 1984 Camaro z/28 LG4 auto 1971 ElCamino SS454 -Tremec 5 spd |
69rad we suggest that you only post questions in the one section most closely associated with your problem, so that future searches by other people will find the same helpfull information available to them. It also saves on bandwidth and helps the moderators keep the site clean for searching too. Your post in Brake section was the proper place for it.
It also seemed like this last comment was a little slap in the face to the folks that gave you photos in the brake section where you said it was exactly what you needed there. Just a heads up to choose your words carefully since its hard when reading posts to know the 'intent' of comments.
Click..is Jim..69RS-LM1 350/255 - 700r 4speed auto. "There will come a time when you believe everything is finished, That will be the beginning." Louis L'Amour Our Camaro Webpage Photos for viewing Learn How To Post Pics here |
