Restoration Corner Where originality comes first
Old May 18th, 04, 06:16 PM
68Zgarage 68Zgarage is offline
Tech Team
Post
My car no longer has the correct rear leafs on it. I had seen that D&R sells original appearing 4 leaf, leaf springs that would be correct for the 68Z. Just wondering if anyone has seen a set and how they looked, or is there a better, cheaper set out there somewhere?
68znut
Old May 19th, 04, 02:13 AM
Kyvox Kyvox is offline
Post
Contact http://www.eatonsprings.com/ Tell them the options on your car, and they will build the correct spring. I'm pretty sure they have the corect appearing spring available.
John
'67 SS/RS (RR)
'68 RS conv. (J2)
'68 Z/28 (VV)
'68 Drag Car(ZZ) 11.30 @ 118
'73 Corvette Drag Car 12.64 @ 106
Camaro
Old May 19th, 04, 03:28 AM
Dave69Z Dave69Z is offline
Post
Eaton is reall good to talk to about original springs, I bought a set of z28 replacement springs from Ricks and they had eaton labels on them. I bought the standard version not the concours version for my 69z28, since the 302 is long gone.
Old May 19th, 04, 08:39 AM
stingr69 stingr69 is offline
Post
Last time I spoke to Eaton, they said the springs were exact in function and very close in form but not quite 100% concours correct in appearance. There was talk about a run of exact concours repro's but that idea had been scrapped at that time. Not many people would know the difference anyway.
Maybe it is worth a GP?
Old May 19th, 04, 10:48 AM
Gary L's Avatar
Gary L Gary L is offline
Gold Member
"Tri-Tip"
Post
Rick's catalogue shows style 1 at $199 and style 2 for $379. They tell me that style 2 is exactly correct. Does anyone know what that means and what makes the rear springs correct?
Gary
[ 05-19-2004, 07:44 PM: Message edited by: Gary L ]
Gary, SIM TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original.
http://www.camaros.net/showroom/data/500/DSC00005.JPG
http://www.camaros.net/forums/image....3&type=profile
http://www.camaros.net/showroom/show...0&ppuser=11189
Old May 19th, 04, 11:29 AM
Tonyx33 Tonyx33 is offline
Tony
Post
Gary the correct springs had the pockets for the
rubber insulators to set in you couldn't see
them from the bottom. Got mine for Rick's and
the car sets perfect
Old May 19th, 04, 11:46 AM
Jonesy Jonesy is offline
Mike
Post
I bought my rear springs from HeartBeat City. He has the exact springs if that is what you are looking for. The Eaton springs and Rick's are not technically correct.
Old May 19th, 04, 11:54 AM
Tony
Post
Jonesy don't Rick's get there correct one's
from Heartbeat City
'69 Frost Green Z/28
Old May 19th, 04, 04:48 PM
Unreal Unreal is offline
Gary
Post
i used a new primary spring along with the originals for the other leaves. That way you have the strength of the new spring, but since the pockets are on the shorter leaves, it looks perfect. I also got new square isolators, from espo. most folks sell only the round ones.
Old May 19th, 04, 04:52 PM
bbd564 bbd564 is offline
Post
I think all of the springs come from the same place.
The way I understand this happens is that all the big Camaro vendors get together and place one big order to keep the price down and make this possible. I got the "EXACT" reproductions for a 68Z and found that my car sat too high and I got rid of them and found a set of used originals from CA, broke them apart, blasted and painted them, put em back together. Problem solved. By the way the repro leaf silencers are wrong for the original springs so I reused the originals.
68 RS Z/28
67 L78
Old May 19th, 04, 04:54 PM
Post
Unreal, Who is ESPO? What you described is what I planned on doing until I found the used set?
68 RS Z/28
67 L78
Old May 19th, 04, 05:46 PM
Gary L's Avatar
Gold Member
"Tri-Tip"
Post
Unreal:
Where did you get the new primary spring? Ditto on who is espo.
Gary
Old May 20th, 04, 11:38 AM
Mike
Post
Not all the springs out there are from the same place. They maybe for the major resto companies, but Heartbeats are different.
Tony, I am not sure if Rick's buys theirs from him or not.
Team Camaro Gold Member #14
1967 Camaro RS/z28 - one of 602 made - SOLD
1969 Camaro RS/SS L48 4 speed
1974 Camaro LT-Z/28 4 speed 33K orig
1984 Camaro z/28 LG4 auto
1971 ElCamino SS454 -Tremec 5 spd
Old May 20th, 04, 04:21 PM
Gary
Post
I bought a set of new springs, and took them apart for the primary. ESPO supplies all kinds of coil and leaf springs. 800-903-9019.
Old May 20th, 04, 05:23 PM
Tony
Post
Jonesy I think Gary at Rick's told me thats were
they come from
