Rear Window Molding REmoval - Team Camaro Tech
Camaro Tech General Tech Area
Old Apr 8th, 05, 10:24 AM
mybitchincamaro mybitchincamaro is offline
Tech Team
Default Rear Window Molding REmoval
CAn anyone tell me the easiest way to remove the inner back window molding?seems to be just a pinch type.replacing sail panels.
67rs/ss
396
4sp
deluxe
Old Apr 8th, 05, 01:13 PM
sicsD8 sicsD8 is offline
Default Re: Rear Window Molding REmoval
it pulls right off.
'68 SS 350 4speed 3.31 posi
Old Apr 8th, 05, 02:35 PM
Tech Team
Talking Re: Rear Window Molding REmoval
wow mine is stuck pretty good guess just reef on it
Old Apr 9th, 05, 03:49 PM
MrDanB's Avatar
MrDanB MrDanB is offline
Dano
MBC,
Take a stout, short screwdriver and place it towards the curvy part of the molding sort of near the top of the back window. Gently pull back towards yourself to get it started. It does just "pinch" on the lip of the frame.
During reinstallation, it's generally easier to start at one end or the other...
Good luck!
Dano
If you can't see the bright side of life, try polishing the dull side...
Old Apr 9th, 05, 03:56 PM
Tech Team
thanks seems to be coming off now the hard part(sail panels) next.
Similar Threads
window molding clips KURT Body Shop 3 Mar 25th, 05 07:52 AM
Rear Panel removal ... 77 Camaro sdtsdt Body Shop 0 Jan 11th, 05 04:27 PM
rear window and quarter panel rust bartman915 Body Shop 13 Apr 26th, 04 07:23 AM
Rear Window Installation CamFrk68 Tech 2000 4 May 30th, 01 01:28 PM
