| Team Camaro Tech Current Topic: Blows oil out breether | ||
I have a fresh 383 Stroker, i have about 75 miles on a new engine, the problem is when i drive the car, after the car warms up it blows oil out of the breether about every 15 minutes or so, its a mess it gets all over the engine compartment and worse it end up on exhaust which smokes bad ? Please help if you know the remedy. Thank You Mario
| Sponsored Links | ||
Advertisement | ||
maybe you need a taller breather? are the baffles on the valve covers installed [properly]?
1969 Camaro RS 383 .030 over, restored #332 http://community.webshots.com/user/snakeeyesm3 (daily driver; modified 1987 325is) |
did the rings get properly broken in, or did you fire it up and just start hammering on it?
you don't plan sincerity. you have to make it up on the spot. wanna hear about 20 years ago when i was too smart to know any better? |
are you running a pcv valve also, or just a breather? w/o a pcv, it will just blow the positive pressure from the engine out the breather, making a mess.
or, your rings are not sealed properly yet, which after 75 miles would indicate a problem, likely. or, as was mentioned, if your breather isn't baffled in the valve cover, oil could be saturating your breather, which would explain the quantity you are seeing.
Sean 1968rs, formerly a 406 sbc, 354" SB2.2 coming soon... "Aerodynamics is for people who don't know how to build engines" - Enzo Ferrari |
Breathers without a PCV puke oil pretty regularly IMO, I prefer to run a PCV on one valve cover and a breather on the other. Even with this setup you will still puke a little oil on the valve cover if you spend a lot of time at WOT (there's no vacuum when at WOT for the PCV valve to work)
E85 racer and E85 carb builder www.horsepowerinnovations.com 68 Camaro, E85 powered 427" small block. 9.96 @ 133 MPH, 1.319 sixty foot on motor. 5.92 eighth @ 116 with a 1.42 sixty breaking beams with back tire on the bottle |
Just to re-enforce what was said above. I agree 100%. You need a PCV and a breather (or a breather tank with is what I like to use long with a PCV).
Royce (NO XQSSS) Bradley www.facebook.com/driveyourjunk http://www.youtube.com/watch?v=DSLsGgDjFXE (brief sound/video clip, 3 1/2" exhaust through Borla Sportsman mufflers) |
Something I have been doing for years is to cut the toe end off a pair of old or new soxs. Roll it up like a donut, cut to size and place it under the breather. No more leaks on the valve covers. Maybe get lucky and find a color that matches your car. I took a pair of the wifes blue ones. Whats really funny is when she asks where her blue soxs are and you tell her you decorated your engine with them.
I'd do a compression check to make sure you don't have a ring sealing problem. Strokers will puke a bit more than a stock 350 - especially when hammered. After market valve covers may have little or no baffling inside the cover to catch the mist. You might have to put a puke can on it to catch the excess. Ditto on the PCV system.
Dave ======================== 68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI |
This is my #1 problem on my car and what is driving me to pull the engine again. I get oil coming out the breather filling the airfiler up with oil as well as oil spitting out the dipstick tube. Its called blow by. What everyone has said sor far is true. Since its a new engine and yor probally installed a new set of rings and pistions did you make sure the rings were installed correctly and not all in a straight line where the gap is?
Ive been going though the process of elimintation with checking compression check, vacum check to make sure the system is presureized. Im still coming up short with answers so Im going to pull the engine and start looking inside her for answers. Of course I'll be adding some new goodies in the process. Good luck and post up what you find.
1968 Camaro with a 383 finally done and on the road! |
| Sponsored Links | |
Advertisement | |
Similar Threads
| Oil Sandwich Adapter | DaMan2 | Engine | 9 | Apr 29th, 05 12:43 AM |
| HELP...frozen oil gallery plugs | GWM 68 | Engine | 8 | Apr 11th, 05 10:16 AM |
| Rear cam bearing question. | ck 2 | Engine | 13 | Apr 10th, 05 12:16 PM |
| SB chevy oil pressure | dawg | Engine | 4 | Apr 3rd, 05 04:26 PM |
| Help with removing oil dipstick tube | Granny's 69 | Engine | 3 | Apr 2nd, 05 07:40 PM |
