Accel distributor problem - Team Camaro Tech
Thread Tools Display Modes
Old Apr 16th, 05, 12:52 AM
loneagle loneagle is offline
John
Default Accel distributor problem
I just installed a new Accel billetproof distributor #71100E along with matching coil according to the instructions. I got the unit installed and the engine started right away and ran good for around 5 minutes and died. Wouldn't restart! I checked for spark at the coil wire and found it was very weak. I removed the distributor and checked the wire connections to the module and the mag. pickup, air gap and it all looks good. Tested the coil with my VOM and it checks out too! I would assume the module is bad. Does anyone know how to test the module or have any advice?......... Thanks!
John
'70 Nova, 355 ci, Edelbrock heads #6089, 64cc, 9.8-1 compression, Hyd roller cam 230/236 .510/.520, Scorpion roller rockers, RPM intake, Holley #3310, 1 5/8 Hookers, 2 1/2 exhaust w/ Spintech mufflers, Super T-10 4 speed
Old Apr 16th, 05, 05:47 PM
JohnZ JohnZ is offline
Team Member
John
Default Re: Accel distributor problem
Have you checked their website for diagnostic or trouble-shooting instructions?
http://go.mrgasket.com/InstructionSh...aspx?BrandID=3
JohnZ
CRG
'69 Z/28 Fathom Green
Team Camaro Tech > All Generations > Performance      Current Topic: Accel distributor problem
Location
Location
First Name
Human Verification
Similar Threads
Advice-stock tach on 70 Z28 doesn't work w/ Accel 300+ ignition O.O. 70 Z28 Electrical & Wiring 2 Nov 28th, 04 09:50 PM
12 Volts to Accel HEI Coil ? Rons68 Electrical & Wiring 2 Oct 28th, 02 10:16 AM
Can I use a Accel Ign on a MSD Distributor? scott67ss396 Troubleshooting 1 Feb 8th, 02 03:29 AM
Accel, Pertronix, Proform, Which one is better? 69Man Performance 4 Jul 10th, 01 08:22 PM
Accel HEI distributor problem Eric68 Tech 2000 6 Jul 10th, 01 02:16 PM
