| Team Camaro Tech Current Topic: LS1 Headers | ||
Any opinions on the best street header (ceramic coated) I should use on my 2002 LS1 (6-speed manual) Camaro? I am looking for plenty of low end torque and want power from 1500 - 5500 RPM
Header size, Brand, etc THANKS
| Sponsored Links | ||
Advertisement | ||
Fuzz,
I would try LS1tech.com for your car. There is a lot of information over there if you can get through the bickering.
Kent<br />67 SS 427 |
almost every ls1 header out there is the 1 3/4" primary, so you don't have much choice in the way of size. however after installing a few sets, jethot is basically a hooker header with the thicker exhaust flange, and a better location for the o2s iirc. The patriot headers are a cheap entry level design, and are poorly located so they rest on the k member. becuase of this they send false knock readings to the knock sensors and the k member needs to be cleearanced for them, so i'd stay away if at all possible.
and on almost every long tube you end up having to grind a small casting block off the driver side for clearance issues. good luck edit: from the research we have gathered and reading on other people's experience you cannot go wrong with a set of the hookers and then have them coated, or the jethots (which run a little higher but are worht it.) and steer clear of the patriots if possible.
1969 camaro<br /><a href="http://www.coloradomuscle.com" target="_blank">http://www.coloradomuscle.com</a> |
Hooker/Jet Hot 1 3/4" LT's are a good set of long tubes, but if you want the highest quality I would go with either QTP or Kooks LT's. With best of quality also comes highest in price. You won't go wrong with either three of the headers. Good luck.
The race...The smoke...The rush! The man...The machine...The engine! Future Camaro Owner. ~CHR~ |
| Sponsored Links | |
Advertisement | |
Similar Threads
| Headers of Choice? | rando | Engine | 18 | Apr 26th, 05 05:34 PM |
| 69 BB Headers and exhaust, HELP | Hawaii5-0 | Engine | 3 | Mar 14th, 05 05:34 PM |
| Problem finding shortie headers | paul1969 | Performance | 5 | Sep 24th, 04 07:15 PM |
| Potential of Custom Headers | Tski | Performance | 22 | Jan 23rd, 04 06:11 AM |
| Need help Choosing Headers | Joe 69 | Engine | 9 | Mar 8th, 03 03:41 AM |
