how to change front wheel studs on drum brakes? - Team Camaro Tech
Wheels & Tires What fits what?
Thread Tools Display Modes
Old Apr 25th, 05, 12:23 PM
1Fast69chevy 1Fast69chevy is offline
Rick
Default how to change front wheel studs on drum brakes?
i'm in the process of replacing my front wheel studs and was wondering what is the easiest/best method to go about this. will i have to remove the drum brake assembly and press them out, or is there a way i can whack them out with a hammer and possibly put the new ones in while the assembly is still mounted on the spindle?
the car is a 69 camaro with stock front drums, upgrading to longer studs to run my new draglites.
thanks
Rick
1969 camaro<br /><a href="http://www.coloradomuscle.com" target="_blank">http://www.coloradomuscle.com</a>
Old Apr 25th, 05, 12:56 PM
Everett#2390's Avatar
<Jake-68's rule
Default Re: how to change front wheel studs on drum brakes?
You will have to remove the hub from the spindle as there is not enough room behind the hub to backing plate for the length of stud. Place the lugnut onto the stud and support the back side of the hub and remove with hammer (BFH).
I remove the hub and place support underneath the hole in the flange where the new stud is going to be inserted.
Place the new stud into the hole, use a brass drift punch atop the stud, and install with large hammer (BFH). Do not hammer directly onto the stud. Make sure there is 360* support about the hole.
Finish the install by using an extra OE lugnut turning it around, using the flat side, and two washers and plenty of lube on the washers and the threads to pull the stud squarely into the hole.
Parallelism/concentricity of all five studs can be proven with the brake drum install. Minor alterations of drum stud holes can be accomplished with a round file.
I've had good luck wth this method and the drum has slipped over the studs without any other action.
Old Apr 25th, 05, 04:15 PM
Rick
thanks
i'm going to tackle the project on saturday
Old Apr 25th, 05, 04:30 PM
CarlC CarlC is offline
What Everett said, and....
Don't whack the studs while the hub is still on the car to remove them. It will wreck the wheel bearings. Remove the studs with the hub on the workbench.
Carl's Camaro
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Wheels & Tires      Current Topic: how to change front wheel studs on drum brakes?
Location
Location
First Name
Human Verification
Similar Threads
Door adjustment jsouthco68camaro Body Shop 9 Mar 7th, 05 06:46 AM
Trunk Lid Fit Problem RPOL72 Body Shop 8 Aug 27th, 03 02:45 AM
How do you adjust drum brakes ? jr68 Brakes, Suspension & Steering 5 May 24th, 03 03:47 AM
Wheel studs? Chopper Troubleshooting 2 Apr 6th, 03 05:44 PM
JL-8 Wheel Studs jvolk81 Brakes, Suspension & Steering 6 Mar 14th, 01 06:47 PM
