| Team Camaro Tech Current Topic: What Cam Is This? Number 221508? | ||
| Engine General Engine Discussion. |
OK,
Got the cam out(STUPID FUEL PUMP!!!) But want to know what cam I have. The only markings on the back of the cam are 221508 Thats it. Also a light tan dot but other than that...nothing. How do I determine what cam this is OR what manufacturer made it? Any help would be appreciated. It came out of a goodwrench 350 chevy but it definately does not sound stock. Thanks Mark TOOFUN |
| Sponsored Links | ||
Advertisement | ||
SOMEBODYS gotta know!!....anyone? bueller? bueller? anyone
Don't have a clue...
The number looks like an Iskenderian number and they stamped theirs on the end - but , I 'googled' it just to see and got nothing... Maybe a special grind for a retailer (summit,paw or ???) - you might try calling Isky and see if they can ID.
1968 Convertible Some trucks ![]() Other V8 things - some of which float Other V6 things - none of which float ![]() Oh yeah, and 1 "Straight-Six" ... ![]() If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Not an ISKY. Called and they said unless it has their name on it, it would not be theirs. Thanks for the try. This must be a tough one. I havent been able to find anyone who can answer it. Even called a GM dealership and asked them to look it up. They said it wasnt theirs either because it was missing some digits. It is a very new cam, so nothing has worn off of it. I looked over it very very carefully and no other markings on the back or front. There is a D 8 on it between two lobes then a 1539 further down between two lobes and finally a 26 at the other end between two more lobes!!
Lots of off-brand cams these days being made for companies like jegs, PAW, summit etc. May be tough to track down.
'68 SS 350 4speed 3.31 posi |
Called Jegs, summit, paw, crane, comp cams, isky, lunati(holley), edelbrock. Just about anyone and everyone. ALL say the same thing. If it doesnt have our name on it it isnt our cam!! Not a damn number on it!! so let me try this approach. Does anyone know the stock grind number for a GM GOODWRENCH 350 motor? At least that way I can eliminate the fact that it is not stock.
Mark |
LOOKED AGAIN AND FOUND THIS BETWEEN THE LOBES CWC 1539 Does this help?
mark |
The only thing you can do it stab it back into the motor, set up a dial indicator and wheel, and find out the specs. Who cares who made it? All that is really important is the duration, lift, and LDA. You can find those out fairly easily.
Matt Jones Lead Mechanical Engineer Art Morrison Ent. Inc. |
That's the type of the numbering system that GM set up with CMC (Camshaft Machine Co.) for the cams that went into their products. I have no (specific) info with those numbers anymore, but that's what it looks like! They closed about 15 years ago, and made the cams available through the Wolverine/Blue-Racer line, but used an entirely different numbering system. And as far as I know there never was an interchange system set up. Thanks, Gary in N.Y.
So is it safe to say that this is a stock cam application?
#11
My Elgin, Clevite, old G/K, Melling, TRW and old WBR listings don't list a number like that so can't help???
I figure that number is actually 221-1508 Melling lists 221XX and Clevite 229-XXXX Sorry, pdq67 |
#12
The Camshaft Machine Co. numbers were either/or, in other words the stock and the performance cams used the same numbering system, just had different numbers. If it's one of theirs, it could be either. If I come across their old catalog I will get back later. Thanks, Gary.
#13
Hello Gary,
Thanks I really would appreciate it!! Mark |
#14
Cant help myself, once I lock my mind to something I cant break away from it until I figure it out.... On that note, found the CAMSHAFT MACHINE COMPANY after searching numerous other search engines with no success on DOGPILE.COM LOVE THAT SEARCH ENGINE!! Anyways, called them and they punched in the six digits and TADAAAA!! IT CAME UP!!! They are faxing over the specs today so should have them soon. Just in case anyone else ever runs into this problem, I have posted their contact info below.
Camshaft Machine Co. Firm Type: Private Company, Headquarters Location Address: 717 Woodworth Rd. City / State / Zip: Jackson MI 49202-1654 Country: United States Main Phone: 517 787-2040 THANKS MARK TOOFUN |
#15
FAX JUST CAME IN. ANYONE CARE TO DIGEST THIS FOR ME? Thinking of going with an XE-268H COMP CAM?
CAM LIFT VALVE LIFT LOBE CENTERS INT EXH INT EXH INT EXH .325 .325 .488 .488 106 110 ADV.DURATION SAE DURATION 050 DURATION INT EXH INT EXH INT EXH 292 300 300 308 232 234 SAE TIMING LASH BTC ABC BBC ATC HYD 39 81 79 49 050 TIMING BTC ABC BBC ATC OVERLAP 80 10 42 47 7 SPREAD 108 ADV TIMING BTC ABC BBC ATC 39 73 79 41 |
| Sponsored Links | |
Advertisement | |
Similar Threads
| Cam break in | edd Gordon | Engine | 1 | Mar 25th, 05 05:55 AM |
| 1970 LT-1 cam .459"/.485" .242*°/254° @ .050" what's the adv duration? | JIM68 | Engine | 7 | Feb 4th, 03 08:31 PM |
| 274xe vs. hot cam on vortecs | czar | Performance | 20 | Jul 16th, 02 11:01 AM |
| GMPP & Comp. XE256 cam comparison in 327 | Granny's 69 | Performance | 9 | Jun 10th, 02 03:13 AM |
| removing cam - it got stuck - I used a pry!!! trouble??? | caribbean camaro | Engine | 11 | Apr 5th, 02 12:16 PM |
