Copo & Dealer Factory & Dealer Performance
Old May 6th, 05, 06:37 PM
moneypit moneypit is offline
Tech Team
Default jl-8 axle flange? Tapered or common?
I thought that I read somewhere that only jl-8 rear-ends had tapered flanges?! Is that correct? or am I just wishing? Reason is that i am removing rear-end from car and the axle tubes are tapered at end? (aftermarket set of flanges installed) Thanks!
'69 Z28 Clone - Driver<br />'69 Camaro project<br />'77 Camaro - Mild Street
Old May 7th, 05, 02:47 PM
HawaiianCamaro HawaiianCamaro is offline
Jeff
Default Re: jl-8 axle flange? Tapered or common?
Heres a short article from the Camaro Untold Secrets site of W Guinn. Whats the rear end code on the tube? That would help you out greatly.
http://www.camaro-untoldsecrets.com/...article_fs.htm
Jeff
IF YOU DON'T STAND BEHIND OUR TROOPS,
PLEASE, FEEL FREE TO STAND IN FRONT OF THEM !!!
http://www.camaros.net
http://www.yenko.net
Old May 9th, 05, 09:01 PM
Jeff H Jeff H is online now
I think all 12 bolts have tapered axle tubes except the HD service package rear with disc brakes. The factory JL8 rear was just a standard 12 bolt rear that they welded on the JL8 brackets and parts. It's most likely a standard 12 bolt rear. What are the codes on it?
Jeff H
69 Z28 Hugger Orange original factory JL8 brakes, cross-ram & GM fiberglass hood, TI setup, heater and radio delete, Stahl headers, Minilite wheels - being restored
00 Camaro SS daily beater
Similar Threads
9" axle spline engagement depth Neals69SS Transmission & Driveline 7 Aug 2nd, 04 04:55 PM
67 Camaro Radius Rod - Axle bracket orientation jknotts Brakes, Suspension & Steering 0 Apr 28th, 04 02:27 PM
1968 Camaro axle width? smits67 Engine 5 Feb 12th, 03 02:08 AM
full quarter replacement - tail flange skreese Body Shop 7 Jan 23rd, 03 05:26 AM
Floor Pan Flange Edwin69 Body Shop 4 Oct 20th, 00 07:06 PM
