Vertical body measurements - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old May 6th, 05, 07:16 PM
sjg34 sjg34 is offline
Tech Team
Steve
Default Vertical body measurements
I am trying set my body on a dolly and I am referencing the fisher body manual and nothing makes any sense. The manual shows the front subframe mount at the firewall to be 13 13/16 and the bottom of the rear frame at the leaf spring mount 11 3/4 . I am not able to duplicate the dimensions on the doll, nor do I believe the front is 2” higher than the back. My rockers are level and the body doesn’t appear to be kinked.
Old May 6th, 05, 08:28 PM
67CruiseMasterCamaro 67CruiseMasterCamaro is offline
Arrow Re: Vertical body measurements
Actually I haven't measured one before. But, That measurement does seem right to me. I mean since I have been working on my car, had it on jackstands and messing around with both the firewall body mount and the leaf mount, the correlation does sound correct. I would have to set my car up to check it, but maybe someone else will chime in on this thread to validate the measurements. Sorry I couldn't help.
Scot
Cars I own!
1967 Camaro RS/SS w/K30 Cruise Control
2005 GMC HD2500 Duramax
2008 Corvette Z06
2008 Mercedes C300 Sport
and soon 1969 Camaro Z/28 Fathom Green X77
Old May 6th, 05, 09:00 PM
Tech Team
Steve
Default Re: Vertical body measurements
Did you level the rockers and set the rest of the dimensions? Because....if i try to get the frame dimensions right the car is running up hill like crazy
Old May 6th, 05, 09:34 PM
gene_sc gene_sc is offline
geneo
Uh the 11 3/4 is to " Lower surface of side rail at kickup either side of rear axle housing" . the measurment at rear spring mount area is 6 15/16 to the "Master gauge hole side of rail"
http://mysite.verizon.net/gene_sc/frame.htm
Old May 7th, 05, 10:37 AM
Tech Team
Steve
I have your spec sheet, a – c are the same, but I have a “d” that is to the aft mount of the front subframe. My e is the same as your d (location and dimensions). But the last 2 dimensions are swamped. I have the shackle mount as 11 ¾ and yours show it to be 15 11/16. Does the fisher body manual have a typo? I tried to add a screen shot to the post but I don’t know how
Old May 7th, 05, 10:53 AM
geneo
Mine came from "body by fisher 1967 service manual" section 3-12 to 3-14. maybe you could e-mail me your diagram so I can compare them... If I have time today I'll try to set a car up and do some quick measurements
Old Jun 10th, 05, 04:21 PM
Gene, did you ever check the dimensions on the frame diagram? I am curious as to how this came out. I am going through the measurements this weekend.
Scot
Cars I own!
2008 Corvette Z06
Old Jun 10th, 05, 04:43 PM
geneo
Scot
Sorry I have been so busy lately and had a death in the family. I have the convert in the air right now....(gotta like the rotisserie, so easy to work on) I will do some quick measurements Sat and post the info. I really think the manual is correct... measuring a uni-body can be confusing when you don't do it alot.
Old Jun 10th, 05, 04:58 PM
Gene, the first page refers to page 2-7, the second page on your website is figure 3-17. Are there pages missing that we need to match up the measurements like figure 3-14? I have a 68 Chassis manual but it only give info on the subframe.
Scot
Scot
Cars I own!
2008 Corvette Z06
Old Jun 10th, 05, 05:49 PM
Tech Team
Steve
I noticed that Gene’s and my measurements were different. I had an extra dimension but the main problem was his rear shackle mount and my dimension over the rear axle was swapped. The only way I could get it to come out was to use his rear shackle dimension and omit the rear axel dimension. Once that was done all the other points fell into place.
  #11
Old Jun 10th, 05, 05:57 PM
Thanks sjg34, but it still doesn't explain why the missing page or pages. I don't have a manual, maybe if I had one I would understand. But just the same, this is why I am asking the question to Gene. He will know. By the way, thanks for your reply.
Scot
Cars I own!
2008 Corvette Z06
  #12
Old Jun 10th, 05, 06:11 PM
Tech Team
Steve
check your mail. It may help
  #13
Old Jun 13th, 05, 08:25 PM
geneo
Hey guys sorry it been so long to answer...
I am coming up with the same as below... I am going to double check after I setup a datum line, to get exact measurements (note I have sub frame off) so it will be the rear body section. The pages I posted were from different soeces so the gif number and page number do not match up.... after I get this measured I will re-do my page and diagrams
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Vertical body measurements
Location
Location
First Name
Human Verification
Similar Threads
Confessions of a body shop owner. MARTINSR Body Shop 39 Dec 6th, 12 02:51 PM
Cheap repro body panels Pci_RAID Body Shop 11 Jun 10th, 04 08:42 AM
Sub Frame Reconditioning socal68rs Body Shop 11 Aug 13th, 02 10:16 AM
LA car vrs NOR car allcamaro Tech 2000 22 Oct 7th, 00 02:44 PM
