Factory style roller cam with sbc cam - Team Camaro Tech
Thread Tools Display Modes
Old May 11th, 05, 10:25 AM
MarkM MarkM is offline
Default Factory style roller cam with sbc cam
I'm builing 383, and I intend on using a small base circle cam. The block I'm using is a '88 year block, and I intend on running a factory style roller cam/spider/lifter retainers, etc.
My question is, since the sbc cam drops the lifter down some in it's bore, will the lifter drop down far enough to exit the bottom of the lifter retainer?
Also, anyone know if there is a max cam lift to use, so the lifter body doesn't come into contact with the bottom of the lifter retainer?
Old May 11th, 05, 08:06 PM
BPOS BPOS is offline
Al
Default Re: Factory style roller cam with sbc cam
I'll let you know! I'm installing a reduced base circle cam here real soon in my roller block. I hope the answer is "NO".
The way I understand things, there is no "standard" base circle on performance cams. They need to alter the base circle that the lobes will pysically fit past the cam bearings when you install it. The bigger the lobe lift, the smaller the base circle.
69 PJ Convert, RS added, 383, Pro-Filer 195s, 2004R, 3.73 posi 8.5, C6/LS1 Brakes, etc "Big hitter, The Lama....long." Carl Spackler
Old May 12th, 05, 08:11 AM
I called the Comp Cams tech line. They said to order the cam with no more then 0.050" undersized. He said something about a potential problem of the lifter droping down to low, and loosing it's oil pressure.
Team Camaro Tech > All Generations > Performance      Current Topic: Factory style roller cam with sbc cam
Location
Location
First Name
Human Verification
Similar Threads
Cam and roller lifter/rockers 67CruiseMasterCamaro Engine 2 Feb 26th, 05 04:41 PM
roller cam specs vr1967 Performance 3 May 14th, 04 04:14 AM
Solid roller cam advice??? Erik Beckett Performance 24 Feb 14th, 04 01:26 PM
Solid roller cam and lifters for everyday use? paul1969 Performance 34 Feb 14th, 03 07:36 PM
Cam / Roller / Rockers / Headers - Need Suggestions For A 97 Z28 Gonzo Tech 2000 4 Oct 26th, 00 06:46 PM
