Fourth Generation 1993-2002
Old May 11th, 05, 05:17 PM
dahoe002000 dahoe002000 is offline
Default carbureted 93-97 f body
I am building a 406ci sbc for a g body but i am wanting to put one in a newer car. I was wanting to know if anyone has put a carbureted motor in a f body 93-97 and what kind of trouble did you run into.
William
406ci sbc
Eagle 4340 steel crank
Eagle 5.7 H beam rods
SRP/JE 4.155 flat top pistons
Edelbrock Victor Jr Bowtie II intake
Holley 750 double pumper
Comp Cams 294 Extreme Energy
AFR 195cc aluminum heads
Old May 11th, 05, 08:59 PM
speedfreak2 speedfreak2 is offline
Tech Team
WrenchingAce
Default Re: carbureted 93-97 f body
If this is a daily driver then it won't pass the visual inspection at your local I/M station for one thing. You will never get to drive this thing anywhere except the race track.
Old May 11th, 05, 10:15 PM
CFunK CFunK is offline
Call me Funk
Not sure where he is from but in GA we don't have a visual inspection, just emissions.
Doesn't help with his question but.......
Old May 12th, 05, 03:40 PM
Beers Beers is offline
If you are from ga, fl, ect were they dont test that isent a problem
Old May 12th, 05, 03:54 PM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
The way the 4th gen is setup you may run into issues with the distributor as the engine sets deep under the cowl. Other issues will be engine mounts and pan clearence. These are over come when installing an LT1 in an older car so reverse engineering may work. I don't know how you'll get around the dist issue though...
My advice is keep the LT1 and hotrod it with aftermarket parts (heads, cam etc) and have something better than the 406...
...Dennis
White Wonder
The Nova
Photo Album
www.camaroslimited.com
Old May 12th, 05, 06:49 PM
novaderrik novaderrik is offline
i saw a mid 90's Z28 at the dragstrip once with an old school carb'ed small block. the distributor was waaaaay back under the cowl, and they actually had to cut a notch in the cowl just to get the carb in there. it had a Victor Jr intake with a 1" spacer, and the bottom of the carb was just barely lower than the cowl. they had a HUGE cowl hood on it- like 6" tall- just to cover it up- which looked really dorky on such a sleek car.
but it would bolt right in using stock LT1 mounts and manifolds or headers. not something i'd want to try- the engine would have to come out just to remove the distributor.
you don't plan sincerity.
you have to make it up on the spot.
my 1974 Monte Carlo & 84 Turbo Buick
86 Monte SS that should probably be crushed
Old May 12th, 05, 07:43 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Team Member
Scott
It would fail emissions too, I might guess.
Old May 14th, 05, 09:29 AM
IT WILL BE A DAILY DRIVER AS WELL AS A WEEKEND WARRIOR AND WERE I LIVE WE DONT HAVE INSPECTIONS ON VEHICLES
Old May 14th, 05, 09:33 AM
Thanks For All The Info But I Think I Will Give It A Try To See What Happens
Old Dec 5th, 06, 11:22 AM
1997RSblack 1997RSblack is offline
i've seen it done MANY MANY times... you WILL have to cut a notch in the cowl for the distributor.. other than that.. its basically a bolt in deal if you already have the V-8 mounts...
Similar Threads
Confessions of a body shop owner. MARTINSR Body Shop 31 Jan 30th, 04 03:28 AM
Problems ever since replacing body bushings. (with pics) RamJam Body Shop 9 Sep 24th, 03 07:29 PM
Sub Frame Reconditioning socal68rs Body Shop 11 Aug 13th, 02 10:16 AM
LA car vrs NOR car allcamaro Tech 2000 22 Oct 7th, 00 02:44 PM
