troubleshooting 89 camaro fuel problems - Team Camaro Tech
Troubleshooting Diagnosing problems done here.
Thread Tools Display Modes
Old May 27th, 05, 04:17 PM
Jenna Jenna is offline
Question troubleshooting 89 camaro fuel problems
The car has a fuel problem , not sure if its the fuel filter , pump , or relay . Someone said to jump strat the relay . Iam not good wit reading , can someone send me a diagram . Please , Thank you so much .
Old May 27th, 05, 08:42 PM
Everett#2390's Avatar
<Jake-68's rule
Default Re: troubleshooting 89 camaro fuel problems
The fuel pump relay is located on the firewall just in front of the driver hood hinge. The black box. One can pull the relay and jumper across the large wires to make the fuel pump work.
Usually, the relay gets some carbon spots upon the contacts, it makes for a resistive value and lowers the available voltage to the fuel pump. One can measure the voltage drop across the contact points and if one sees more than 0.5 volts with the relay closed, one would replace the relay.
Welcome to the Club
Team Camaro Tech > All Generations > Troubleshooting      Current Topic: troubleshooting 89 camaro fuel problems
Location
Location
First Name
Human Verification
Similar Threads
1988 Camaro fuel system adambomb777 Troubleshooting 3 Mar 1st, 10 06:31 PM
fuel problems alman318 Troubleshooting 1 May 22nd, 05 09:45 AM
Fuel problems trickster Troubleshooting 9 Feb 22nd, 03 09:44 AM
Tach problems with elec. fuel pump? ntp Troubleshooting 1 Oct 27th, 02 08:19 PM
84 Camaro with Vacuum Hose Problems DicksoN Troubleshooting 1 Mar 5th, 00 03:31 PM
