| Team Camaro Tech Current Topic: Stripped hole on Muncie casing | ||
One of the four bolt holes that holds the input shaft retainer is in bad shape. Can I have this heli-coiled or is it time for a new casing. If it can be done, what would be a reasonable expense for such a fix?
Thanks Phil |
| Sponsored Links | ||
Advertisement | ||
heli-coil's are usually stronger than the original threads(if done correctly).
shouldn't be a problem.you'll need a drill(press would be better).and some steady nerves!i believe the kits are around $70 but i think they come with taps or drill bits,or both. where's BillK when you need him?LOL! Eric
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms |
Bill K is hiding in the background
Helicoils will work fine. I think Wally www.muncie4speed.com automatically does every hole in the transmissions he rebuilds. If you brought it to me for repair it would be $20 per hole.
Bill Koustenis Owner Advanced Automotive Machine Waldorf Md 1971 Chevelle "Heavy Chevy" original owner Enginerepairshop.com |
Thank you
![]() LOL! Eric B
| Sponsored Links | |
Advertisement | |
Similar Threads
| Pressure Plate Bolt Hole Stripped | Gary L | Transmission & Driveline | 2 | May 13th, 05 07:28 PM |
| got a stripped bolt hole | 68RSdroptop | Restoration Corner | 3 | Feb 3rd, 05 06:14 PM |
| Stripped spark plug hole, help. (cavalier) | MarkM | Engine | 9 | Jan 22nd, 03 02:47 PM |
| Stripped a header bolt hole | 69CamaroSS | Troubleshooting | 5 | Nov 1st, 00 03:36 AM |
| cutting hole in tranny hump for muncie conversion | bh3chevy | Tech 2000 | 14 | Jun 29th, 00 01:02 PM |
