Copo & Dealer Factory & Dealer Performance
Old Jun 8th, 05, 10:35 AM
Farm Boy's Avatar
Farm Boy Farm Boy is offline
Steve
Default ZL-1 cylinders
Did 1969 ZL-1 engines have high silicone aluminum cylinders like the Chevy Vega? I worked at a Chevrolet dealer as a mechanic in the early 70’s and although I never saw a ZL-1 I had the misfortune to see a lot of Vega’s, all of them burning oil, overheating, or both.
Steve
1967 Camaro
I drove it for the first time in 1972 when I was 15.
1956 Bel Air Sport Coupe
Better looking than a '56 Ford or Plymouth.
Old Jun 8th, 05, 11:07 AM
Vintage 68's Avatar
John
Default Re: ZL-1 cylinders
The 1969 Zl-1 Aluminum Block, Part #3952318*/casting #3946052**, had Iron Sleeves (serviceable, not cast-in) and thread inserts for the main bolt holes.
The Vega 'high-silicone' castings were actually not as bad as some people thought - just weren't able to tollerate any abuse, like missed/long oil change cycles, that most iron blocks weren't effected by. The failure to service/maintain the cooling system was the major cause of failed engines in most of the Vega's that passed thorough my stalls. Usually 'ate' the head gaskets and then the "fun" really started, scored cylinders & ect... The rebuilders never did get the "Hone/Lapping" process down right, so sleeving became the norm.
My relatives had one (cute '72 'yellow' fastback that I always liked!) that went over 200,000 miles on original engine (no iron sleeve retro.) and wasn't using excess oil until the bitter end. BUT, I had them changing the oil on schedule and replacing the Coolant every 2 years no matter what.
I still have a couple "Coolant Level" retrofit kits in my shop - wonder what they would be worth on 'e-pain'...
John
note:* later changed to 3963516 - ** other #'s (like 053)reported but, I've never seen one in an original car yet.
1968 Convertible
Some trucks
Other things - some of which float ...
Eagles may soar - but Guinea's don't get sucked into jet engines ...
It's never to late - okay, maybe now it is ...
WE NEED MORE COW BELL !!!
Old Jun 8th, 05, 11:42 AM
Farm Boy's Avatar
Steve
I have installed many of those low coolant sensors in those tiny Vega radiators. I was a 17 year old apprentice mechanic paid by the hour. The journeyman mechanics worked flat rate and did not want the warranty or campaign work as Chevrolet did not give them much time (money) for those jobs. I was fresh out of high school and the only mechanic at the dealership with a smog license.
I doubt you will get rich selling those kits as I have not seen a Vega on the road in years (decades).
Steve
Steve
1967 Camaro
Old Jun 8th, 05, 12:03 PM
Vintage 68's Avatar
John
Red face Re: ZL-1 cylinders
Steve
Yeah - I got a whole shop full of stuff that wouldn't ever make me rich... Except for that little ragtop in the corner...
I go out by you on 132 on the way to Yosemite every once and a while. Nice area.
I quess you do some business with Jim Dyer in Stockton? Do you get to the Turlock meets regularly? I missed this year, hope to hit the next one. Some great stuff at those meets!
Keep an eye out in your rearview for 'Clill' - he's known to tear the roads up in that area from time-to-time
John
1968 Convertible
Some trucks
Old Jun 10th, 05, 01:11 AM
davidpozzi davidpozzi is offline
David Pozzi
I've got a friend with a Cosworth Vega, It's the only one I've seen around, those things flat dissappeared! kinda like the Pinto, you don't see those around either.
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
Old Jun 10th, 05, 11:27 PM
Shtgnr Shtgnr is online now
1
Bill
Old Jun 17th, 05, 02:52 PM
JOE58 JOE58 is online now
Chevy made a few different aluminum big blocks other then the ZL1 block but the others were never sold in a car. They made a 4.400 bore block with Siamese cyl that became known as the Can Am block. Some of them had iron liners but there were some made with no liners. They used a special coated piston.
Old Jun 18th, 05, 10:57 PM
kjg67 kjg67 is offline
Tech Team
Kelly
Smile Re: ZL-1 cylinders
There was an aluminum small block in a few Z28's sometime in the late 70's.
I have seen articles about them.
Old Jun 19th, 05, 02:42 PM
JohnZ JohnZ is offline
Team Member
John
Nope - not from the factory.
JohnZ
CRG
'69 Z/28 Fathom Green
Old Jun 19th, 05, 06:45 PM
Tech Team
Kelly
Unhappy Re: ZL-1 cylinders
I think it may have been the Yenko Z I was thinking of.
Similar Threads
rear wheel cylinders - same part # for both sides? Spames Brakes, Suspension & Steering 3 Jul 1st, 03 03:44 PM
Convertable Cylinders RickB1B Tech 2003 7 Apr 30th, 03 11:14 AM
Convertible lift cylinders Performin Norman Body Shop 7 Mar 11th, 03 07:33 AM
convertible top cylinders drptop70ss Tech 2000 4 Apr 10th, 01 05:41 PM
68 Camaro wheel cylinders joev Brakes, Suspension & Steering 7 Mar 16th, 01 03:07 PM
