Values Of Torque Plate Honing - Team Camaro Tech
Old Jun 9th, 05, 08:52 AM
CNC BLOCKS N/E CNC BLOCKS N/E is offline
Banned
Default Values Of Torque Plate Honing
This is a pic of a 454 block that has come in for some work as it only has about 3200 miles on it since the rebuild and it was making some lower end noises. We line honed it and squared and decked it flat and bored it and we blued up the 2 center cylinders installed the gasket and torque plate and went in for 6 strokes on each cylinder as you can see the results and look at the piston as it has blowby right to the oil controll rings as we could measure .003 distortion on the cylinders.
I am posting this as Gary from NY say there is no differance using a plate with what I have seen so far over the years I am a believer. I have done blocks this way and gone trade shows and guys are amazed at what a torque plate does to a cylinder and on the after market blocks the distortion is minimal compared to the OEM stuff.
Comments are welcome
Old Jun 9th, 05, 08:58 AM
Silver69Camaro Silver69Camaro is offline
Matt Jones
Default Re: Values Of Torque Plate Honing
That's awesome, I love visuals like that.
I'm curious, I wonder if it would be any different cylinder distortion with studs vs. bolts? I can picture in my head how it could possibly change things, but in reality I wouldn't think there would be much of a difference. I guess the tension on the threads/block is the main thing to consider, not the combined loading (shear and tension) that occurs with bolts.
Good work!
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Old Jun 9th, 05, 09:16 AM
Banned
Matt
I have found that studs destort a little more as the fine thread on the stud have more mechanical advantage and clamping strenth over coarse threads.
Old Jun 9th, 05, 09:24 AM
dawg's Avatar
dawg dawg is offline
Harry
as a rule i always have my blocks torque plated
Dawgs 69
406 stroker
us navy retired
http://www.northeastf-bodyassn.com/
Old Jun 9th, 05, 10:41 AM
novaderrik novaderrik is offline
there's gotta be a reason Chevy was bragging up the fact that the new LS7 uses a torque plate to eliminate knocking and oil consumption problems..
hmm, i wonder if this might have something to do with all those genIII powered cars and trucks running around burning oil and making knocking noises?
you don't plan sincerity.
you have to make it up on the spot.
wanna hear about 20 years ago when i was too smart to know any better?
Old Jun 10th, 05, 04:49 PM
Eric68 Eric68 is offline
Eric
Cool pic Carl . . .
I wonder if rebuilds and boring the blocks out cause the thinner cylinder walls to "flex" more when the head bolts / studs are TQ'd ???
. . . or maybe it is certain castings? I know some castings don't have as much meat as others . . .
I'm still wondering how GM / Ford / Chrysler got away without using TQ plates from the factory for so many years . . .
E85 racer and E85 carb builder
www.horsepowerinnovations.com
68 Camaro, E85 powered 427" small block. 9.96 @ 133 MPH, 1.319 sixty foot on motor. 5.92 eighth @ 116 with a 1.42 sixty breaking beams with back tire on the bottle
Old Jun 10th, 05, 08:16 PM
Banned
Originally Posted by Eric68
Cool pic Carl . . .
Eric
Thats why we sonic everthing that comes in the door except the after market blocks and I have heard before that some block are factory plate honed but I'm not sure on that one.
Old Jun 10th, 05, 10:54 PM
davidpozzi davidpozzi is offline
David Pozzi
Carl, great photo, I'm a believer!
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
Old Jun 11th, 05, 10:49 AM
JohnZ JohnZ is offline
Team Member
John
All of the newer Chrysler engines (3.7 V-6, 4.7 V-8, and the 5.7 and 6.1 Hemi) are both bored AND honed with torque plates; primary reason is for good ring sealing for reduced emissions and blow-by.
JohnZ
CRG
'69 Z/28 Fathom Green
Old Jun 11th, 05, 11:21 AM
Banned
I'm sure there is more of this going on then we know about
Old Jun 11th, 05, 12:00 PM
BPOS BPOS is offline
Al
My machinist uses a head gasket between the torque plate and the block, preferably of the same type that will be used in the final build. Is this common practice?
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Jun 11th, 05, 01:55 PM
jcdubs's Avatar
jcdubs jcdubs is offline
Jeff
Wow, that is incredible, Great pics. I also believe!
Jeff
My Black 67 - 400 Dart Little"M", SRP 10.2:1, 4340 Scat rotating Assy, Solid Roller, AFR 210 Eliminators, Jesel shaft rockers,Super vic, Prosystems 847CFM, Tko600, 12 bolt 4:10 Eaton posi W/ Strange Hy-Tuf race axles and eliminators.
Best E.T. June 6 09 (11.96 @ 118.06) N/A
71 SS 396 Classic Copper 4 Spd
Old Jun 11th, 05, 10:09 PM
Banned
When we machine a block for an engine builder or machine shop we make them fill out a spec sheet to see what they are using for head gaskets and either head bolts or studs.
Similar Threads
rear seat reinforcement plate or torque box fab 67RS/SS406 Body Shop 7 Dec 9th, 03 04:32 AM
Old License Plate Values? 67L48 Tech 2003 9 Apr 18th, 03 03:52 AM
Disappointed: No plate honing available! jmr1965 Engine 11 Aug 3rd, 02 10:36 AM
balance plate location b-boy Engine 6 Apr 17th, 01 03:04 AM
Suspension location torque values pdq67 Brakes, Suspension & Steering 6 Jun 23rd, 00 01:09 PM
