ZL-1 block????? Ebay....... - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Jun 25th, 05, 12:03 PM
x22d80ragtop x22d80ragtop is offline
Bryan
Default ZL-1 block????? Ebay.......
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4558494427
Hmmmmmmm. Car #49????? Left out the #1. Real deal??????
--X22d80ragtop
1969 Z/28 Cortez Silver, D80 option, 8k tach and gauges.
1969 SS 396/350 Convertible, Cortez Silver,4 speed,D80 option
1971 RS Z/28, classic copper, 8k tach, ugly as u can get.. but a Z.
Old Jun 25th, 05, 01:44 PM
JohnZ JohnZ is offline
Team Member
John
Default Re: ZL-1 block????? Ebay.......
The stamped VIN inside the bellhousing above the cam story is bogus; the engines arrived at Norwood with the flywheel, clutch, and bellhousing already installed from the engine plant, and nobody at Norwood took them apart to stamp the VIN in an oddball location, especially one digit at a time. The VIN he shows is missing the first digit, which would have been a "5", and that would have placed it around Christmas; we built them in February and March (except the first two).
JohnZ
CRG
'69 Z/28 Fathom Green
Old Jun 25th, 05, 04:18 PM
Bryan
You sure it would have been a 5??? The list of the zl1 vin numbers I have show the first car as 569358 and the last as 650977. Car #49 on my list is 619979. Which would have been march. But this list could be wrong. Were the casting dates of the blocks the same month as the build??
--X22d80ragtop
Old Jun 25th, 05, 04:49 PM
rich pern rich pern is offline
Banned
Rich
"The block was devcon filled, which means the water jackets of the block were filled with a solid filler to strengthen the block"
Kinda mute, Looks like the water jackets were filled as well. Can you even remove this? I *think* this block is useless unless it is in a drag car.
Rich
Old Jun 26th, 05, 05:35 PM
Team Member
John
The bogus VIN (69976) is missing a digit, and it couldn't be the last one - would have to be the first one; a "5" in front would put it in December, but it doesn't match either of the known two December cars, and if it was a "6", it would be 50,000 units after the known VIN of the last car (#69). I'm not familiar with the casting dates - should have made some notes while I was there, but who knew in 1969 that anyone would ever care about casting dates? Assembly plants paid no attention whatsoever to casting numbers or casting dates - just part numbers.
JohnZ
CRG
Similar Threads
Big Block Motor Mounts POCO Engine 10 Jun 11th, 05 08:12 PM
Brake Metering block, goes under brake cylinder. journier21 Brakes, Suspension & Steering 6 Jun 11th, 05 07:24 PM
Blue Printing A Block CNC BLOCKS N/E Performance 3 Jun 7th, 05 08:07 PM
Is this a new ebay scam? check it out chevyboy68 Bench Racing 5 Aug 25th, 04 02:35 PM
Is this a new ebay scam? check it out chevyboy68 Bench Racing 2 Aug 23rd, 04 04:50 AM
