Amzoil to Mobil 1 - Team Camaro Tech
Old Jul 5th, 05, 12:11 PM
Mister G Mister G is offline
Default Amzoil to Mobil 1
I have used Amzoil from the start on my 396. Currently looking at another oil change but found Mobil 1 at half the cost. Anyone see an issue with this?
CamaroRS
Old Jul 5th, 05, 01:08 PM
CNC BLOCKS N/E CNC BLOCKS N/E is offline
Banned
Default Re: Amzoil to Mobil 1
We build a lot of circle track engines and we had a couple of customers go to the Mobile 1 and there saw elevated oil temps and the went back to the Amsoil and they were fine after that and we figured there was less protection with the Mobil 1 But for the street it should be fine.
But becareful if it does not say racing on any of the oils made today they have less zink and phosephate which are your friction reducers which flat tappit cam need to live.
I know some engines shops in the area that have found that out the hard way.
Old Jul 5th, 05, 02:39 PM
click's Avatar
click click is online now
Moderator .. Jim
Jim
Mobile recentely introduced 3 new oils for long change intervals with different blends to compete with other oils, hence the cheaper prices on some vs others. When it comes to expensive engines, oil is the last thing you want to save money on. Stick to the Amsoil if you've had good luck with it. I change my 10w-40 amsoil 100% syn, once a year and oil analysis shows its still good for continued use, but I change it anyway. Whats $50 worth of oil in an engine that is worth $4000?
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos for viewing
Learn How To Post Pics here
Old Jul 5th, 05, 05:33 PM
Gary L's Avatar
Gary L Gary L is offline
"Tri-Tip"
What oil then for stock 302, that has zinc and phosphate?
"Government is not reason; it is not eloquent; it is force. Like fire, it is a dangerous servant and a fearful master." ..... George Washington
Gary,TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original.
Similar Threads
15--50 Mobil One silverbbbb Engine 20 Apr 19th, 03 03:52 AM
Mobil 1 synthetic grease for wheel bearings? GlennC Brakes, Suspension & Steering 5 Apr 15th, 03 10:52 AM
Mobil 1 Oil Filter DTL504 Performance 8 Feb 26th, 03 02:52 AM
Mobil 1 Synthetic Differential Lube 1FASTZ Engine 5 Jan 2nd, 03 03:53 AM
Mobil 1 75w-90 Synthetic Gear Oil - Use posi lube? MytMini Engine 2 Nov 23rd, 02 06:02 PM
