To mini tub or not to - Team Camaro Tech
Old Jul 5th, 05, 08:31 PM
67RS RAG 67RS RAG is offline
Default To mini tub or not to
My car is going in for paint and this would be the right time to mini tub. Do you guys think it will hurt the value of the car. I wll be putting a new trunk pan in and the quarters are solid but not original. The rest of the car is. The reason for mini tub is my 17 x 9.5 wheels rub on the inside wheel well. So my choice smaller rim and tire or mini tub. Mini tub will be cheaper and less of a hassle because I could keep my rims as well as the width which i love. The other alternative is I would have to sell my rims buy new ones and get smaller ones. What do you guys think?
Old Jul 5th, 05, 08:54 PM
makoshark makoshark is offline
Team Member
Jeremy
Default Re: To mini tub or not to
My vote goes for new wheels with a different wheel offset. Minitubbing a vert poses more problems with the backseat that`s in the vert`s.
67 Camaro
Old Jul 6th, 05, 09:06 PM
baz67 baz67 is offline
How about running a .125-.250 spacer to move the rim out more? It is cheap and easy.
Old Jul 8th, 05, 12:19 PM
jrager jrager is offline
What size tire are you running on that 9.5" rim?
69 RS Convertible Camaro, 350/350. Orignal red with black top and interior. Hotchkis suspension.
Old Jul 8th, 05, 09:30 PM
I am running 275 40 17, I am running a spacer already to push it out.
It shouldn't affect the back seat should it? After all I think it is onle 2 inches.
Are the verts seats smaller?
Old Jul 9th, 05, 01:37 AM
Rocketrod Rocketrod is offline
Personally I would go with new rims. You never mentioned what the backspacing is on the rear rims?
Rod
69 Camaro with LS2/4l70e
Smoothing firewall and Upper dash panel replacement
Old Jul 9th, 05, 05:22 AM
KevinW's Avatar
KevinW KevinW is offline
Kevin
67, the issue with convertibles is the convertible top frame depends on the location of the inner wheel well for its hinge location. If you mini-tub, you will have to take very careful measurements of the top frame mount points and shave the bracket to the tubs. The rear seat divider is a strength piece too. You have to re-enforce it after you cut it. The convert seat is already shortened from a coupes, you would shorten it more with the tubs. Can you say cozy?
Old Jul 9th, 05, 10:52 PM
Backspacing is 5.5
Aren't the DSE Mini tubs for both verts and coupes?
Old Jan 5th, 09, 05:40 PM
thedugan's Avatar
thedugan thedugan is offline
Doug
Has anybody ever mini-tubbed a vert and can detail out what had to be changed. Thinking of going with the DSE tubs and then a G-Bar setup. Not 100% yet but just trying to get some ideas of what it would take.
-Doug
68 RS/SS Conv
Restoration started 5/2007.
Have it for 08 nope
Have it for 09? nope but it runs and moves
Have it for Spring 2010?
http://www.facebook.com/thedugan789
Old Jan 5th, 09, 06:57 PM
class67's Avatar
class67 class67 is offline
Steve
Call Frank at Prodigy Customs.....their "Project Prodigy" is a vert!
Steve
67 Camaro RS
Old Jan 5th, 09, 07:54 PM
BPOS BPOS is offline
Al
Put a little bigger spacer in there. Or whack the inner house with a big hammer, most likely just rubbing at the very top. Or 255's. Or get different wheels. "mini" tubbing isn't "mini" cheap, or "mini" easy
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Jan 5th, 09, 08:53 PM
BigBlock1969RS's Avatar
BigBlock1969RS BigBlock1969RS is offline
Ed
I haven't mini-tubbed a vert, but did do my own mini-tub on my 69 Coupe. I would think the hinge braces would work the same, just have to be more careful on reusing the braces a vert.
Check this thread out on my experience in mini-tubbing might help answer a few questions:
http://www.camaros.net/forums/showthread.php?t=140271
I'm sure someone (like Frank) with experience in mini-tubbing vert will chime in.
Old Jan 5th, 09, 11:06 PM
CarlC CarlC is offline
Agree on using a small spacer.
If you are not going to use the wheelwell trim have your body shop trim the outer wheelwell lip narrower and re-weld it. It can be narrowed almost 1". Even if you do want to keep the trim it too can be cut narrower, though not as much, to allow for more tire room. My friend did this and the well could easily swallow a 295 with room to spare.
Carl's Camaro
Old Jan 6th, 09, 06:09 AM
ProdigyCustoms ProdigyCustoms is offline
Frank
We have done convertibles and even have top frame braces available to solve the interference issue with the deeper tubs. We had them made when we did Project Prodigy. Without these braces the top would not fold down all the way, stayed up about 5 inches. Now it folds all the way down.
Doing a convertible is harder then a coupe. As mentioned above, the seat mount is more of a super structure on a convertible then just a tin divider like one a coupe. We always do a roll bar and back bracing in our convertible mini tub cars. But I have seen it done without and it works OK. I would jut make sure to close out the ends of the seat brace before installing the tubs.
There is no issue with the top frame other then the change of those braces. The top frame never comes out fo the car during the process.
At the end of the day, it is a PIA at best, but to me worth it to get those big ole tyres in there!
Similar Threads
non DSE mini tub? tharber Brakes, Suspension & Steering 3 Mar 15th, 05 08:49 AM
Mini starter to late model? Mark Yetman Engine 4 Jun 12th, 04 03:49 PM
Gm Mini starter Rick Stewart Engine 12 Dec 27th, 03 06:49 AM
Mini Tubbing a Convertible? V8 Body Shop 4 Apr 27th, 03 03:26 PM
Here's mini starter diagram davidpozzi Electrical & Wiring 7 Jun 22nd, 01 11:17 AM
