68 Wheel well moldings?? - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Jul 17th, 05, 02:30 PM
Erik Beckett Erik Beckett is offline
Default 68 Wheel well moldings??
I have just bought some GM, I hope 68 Camaro wheel well moldings for my camaro. They are in to different wrappers. One you can tell is NOS and the other is newer GM with www.gmgoodwrench.com on them. What exactly did I buy???
Part#:
7995064
7995063
9785880
9785881
4229493
How exactly do these fit in the rear of a camaro, they seem like they would be short in the front or in the back alittle, depending on how you center them on the fender. Can somebody email me photos of the correct fitment on these? Where they located different depending on model of camaro? Mine is a 68 plain car.
Thanks, Erik
67 Camaro Pro Street, 540 Bill Mitchell Merlin big block, Merlin Aluminum heads, Holley 870, hydraulic camshaft, 2" Hooker Super Comp headers, Mallory and Crane ignition system, TH400, 2600 stahl, Ford 9" w/ 4:10 gears and posi.
Old Jul 17th, 05, 03:56 PM
Vintage 68's Avatar
John
Default Re: 68 Wheel well moldings??
Part#:
7995064 = LH rear wheelhouse moulding - 1968
7995063 = RH rear wheelhouse moulding - 1968
9785880 = RH front wheelhouse moulding - 1967~68*
9785881 = LH front wheelhouse moulding - 1967~68*
4229493 = RH rear wheelhouse moulding - 1967
* = part number is the same for both years, they can be used on all 1967 with RS or with RPO-Z21 Exterior Style Trim Option and on 1968 with RPO-Z21 Style Trim - they will require trimming of bottom section to match up with original mouldings if used on a 1968 with RS trim.
1968 rear wheelhouse mouldings are shorter than 1967.
The #4229493 is a 1967 only rear wheelhouse moulding and would require trimming to fit a 1968.
"Mine is a 68 plain car." - then the first four (4) numbers you gave will fit fine.
Use the hardware (screws) provided with them to mount in the existing holes.
Hope this helps;
John
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Jul 20th, 05, 12:33 AM
Beware Beware is offline
Here is a picture of my 68 with the wheel well chrome:
[IMG]
Hope this helps.
Old Jul 20th, 05, 07:49 PM
Thanks but the picture never made it through.
Thanks, Erik
Old Jul 20th, 05, 08:57 PM
HatTrick HatTrick is offline
Default NOS vs "newer GM"
I had the same questions about the web address and NOS stuff answered recently by General Motors. First, GM uses the same part numbers for Genuine GM and reproduction parts. The distinction is the "Genuine GM" label. A reproduction cannot legally say Genuine GM. A reproduction is a "GM Liscenced" product. As far as the wheel wheel moldings one of the 4 for the 68 is still available from the General and others were available recently, so the presence of the web address is OK. If it says Genuine GM then it was made by General Motors or its designated manufacturer and is of original quality and is considered "NOS". NOS isn't technically defined, so even parts that are still avialable can be listed as NOS. I know it stands for New Old Stock, but quantify 'New' and 'Old'. These terms haven't been defined legally or quantifiably. So, after the rambling, I wouldn't worry about the packaging being different. If they are Genuine GM, then they are good parts.
Hope this helps,
Chad
Old Apr 16th, 07, 07:08 PM
chevygrrl chevygrrl is offline
Jane
This is an old thread, but I'm sure someone out there knows the answer.
"The #4229493 is a 1967 only rear wheelhouse moulding and would require trimming to fit a 1968."
What kind of trimming is required here? Both ends? Do the screw holes still line up?
Jane - Plain!
'68 numbers-matching , 327, column-shift Powerglide, Factory AC, currently dark blue/black. We want to return it to correct Ash Gold/Ivy Gold.
Old Apr 16th, 07, 08:51 PM
Jane
bump
Jane - Plain!
Old Apr 17th, 07, 11:03 AM
CFunK CFunK is offline
Call me Funk
You have to trim the front of the trim as it was longer in '67. Not sure about the screw holes.
Old Apr 26th, 07, 09:17 AM
Vintage 68's Avatar
John
Sorry it took a while to get back to you ...
As stated, you need to trim the front/leading edge of the '67 moulding to use it on a '68.
The remaining screw hole locations are the same for both years.
1968 Convertible
Some trucks
Old Apr 26th, 07, 10:43 PM
Jane
My 68 is a standard coupe with the style trim package, not an RS. Do I still need to trim the moldings to align with the RS trim would be? I just bought a pair and am waiting for them to ship. Hopefully, it will all make more sense when they get here. Of course, I would like the installation to be correct.
Jane - Plain!
Similar Threads
Wheel Well Moldings mivy Body Shop 8 May 16th, 03 05:15 PM
68 Wheel well moldings??? Erik Beckett Body Shop 2 Apr 21st, 03 06:59 PM
Difference in 67/68 Rear Wheel Moldings ? Rons68 Body Shop 7 Feb 17th, 03 02:04 AM
finally new wheels and tires michaelm5 Wheels & Tires 14 Jul 12th, 02 01:09 PM
